for those with drag springs
Old August 18th, 2006, 12:43 AM   #1
2001 GT
11.9 @116
DILO2001GT is on a distinguished road
Send a message via AIM to DILO2001GT
i have installed the rears and the drivers side rear is lower than the passenger side and thats without the air as well as the air in the airbag. is that the same on you guys' cars that have these springs. like it looks like the drivers side has a lowering springs in it and the other side is about 3/4 of an inch off. its really noticeable and they are installed the right way. took it to a garage and the guy said they are fine that it was the airbag so let it all out and now a week later and it still sits pretty high on that side. any ideas?
12.04 at 115mph with a 1.9 60'
Old August 18th, 2006, 03:49 AM   #2
2001 GT
11.9 @116
also is there a left and a right spring or does it matter. i think if i switch the springs and the passenger side does what the drivers side is doing i can just pump up the airbag and level it off. am i on the right path? lol
Old August 18th, 2006, 09:14 AM   #3
Drgnracin72's Avatar
i never had a [problem with that. mine sat level when i first put them on and now my car sits a litlle lower on the right rear passenger side.
RIP
ΜΟΛΩΝ ΛΑΒΕ
One Big Ass Mistake America
SHEEPDOGS
Old August 22nd, 2006, 03:00 AM   #4
2001 GT
11.9 @116
could it be because i have yet to install the front springs? i only installed the rears when i did the ca's and shocks. so i only have the rears in and a few ppl told me that the fronts being put in might do the trick. what do ya think?
Old August 22nd, 2006, 06:16 PM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Most drag springs are side specific in the rear. One is stiffer than the other. Personally I wouldn't use them. I've found better luck in stock GT springs. Lowering springs in the rear work good too in a stock suspension car because they are usually a stiffer rate which puts more force on the rear tires.
Old August 22nd, 2006, 07:07 PM   #6
2001 GT
11.9 @116
the airbag is suppose to go in the passenger side right?
Old August 22nd, 2006, 07:12 PM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Yes
Old August 22nd, 2006, 07:58 PM   #8
2001 GT
11.9 @116
hmm i haven't put the front springs in yet so maybe that could be it but i don't know why my drivers side sits over an inch lower than the passenger side. could the lift from the front springs settle it down?b
Threads Similar to: for those with drag springs
Rear Drag Springs jivepepper 99-04 5 August 21st, 2009 02:01 AM
Will eibach drag springs lower my car? black04GT General Tech 16 October 3rd, 2007 01:30 PM
Steeda Drag Springs GreenFaleen General Tech 4 April 11th, 2007 11:27 PM
