Best Way To Get Top Shock Nut Off?
Old November 10th, 2007, 09:56 AM   #1
JohnC's Avatar
1997 Mustang GT
13.56@102.94
JohnC will become famous soon enough
So I have some Tokico shocks I want to install, but I can't get the front top shock nuts loose. How do you guys get these loose?
My attempts almost stripped out the slot on the top of the shaft. No one can seem to hold a big flat head screw driver in there and keep it from turning with the nut either.
1997 Mustang GT
Aluminum Block PI swap & 4R70W to TR3550 swapped.
Best 1/8: 2.04 60ft 8.74@81.85 &
Best 1/4: 2.045 60ft 13.56@102.94
all on stock 245-17's
My Garage
Old November 10th, 2007, 11:55 AM   #2
Resident Bubblehead
00vabchgt's Avatar
00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough
i hit mine with an impact to get it to turn without turning the strut shaft. after it was broken free, i was able to use a wrench to get it the rest of the way off...
Submariners Do It Deeper
Military Crew
MM1 (SS)
Order of the Bluenose
US Navy Veteran
Originally Posted by MamaStang View Post
"Boy Danny....nice cock ya got there. "
Old November 14th, 2007, 09:22 PM   #3
JohnC's Avatar
1997 Mustang GT
13.56@102.94
I don't have an impact, dangit. I suppose I'll end up paying someone to get the nut loose.
1997 Mustang GT
My Garage
Old November 14th, 2007, 09:25 PM   #4
HMUSN's Avatar
iTrader: 9 reviews
breaker bar/ cheater bar worked for me.
Old November 14th, 2007, 10:12 PM   #5
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 7 reviews
+1
TT Build in progress.......
Old November 14th, 2007, 10:35 PM   #6
Resident Bubblehead
00vabchgt's Avatar
take it to Auto Zone or some place like that. they should be able to do it for you...
Military Crew
MM1 (SS)
US Navy Veteran
Old November 14th, 2007, 10:42 PM   #7
JohnC's Avatar
1997 Mustang GT
13.56@102.94
That's the thing, the nut is on so tight that it turns the whole shaft with it inside the shock.
I tried to wedge a huge screwdriver it the groove and against the body of the car, but it flexed and went flying across the motor.
Trust me. I know how to work on cars and suspension, but these shocknuts are stuck good. They have been for a good while, too. Every time I needed to drop the K member or swap the front springs, I always had to remove the two bottom bolts because I could never get the top loose.
1997 Mustang GT
My Garage
Old November 14th, 2007, 10:44 PM   #8
Resident Bubblehead
00vabchgt's Avatar
do like i said here^
Military Crew
MM1 (SS)
US Navy Veteran
Old November 25th, 2007, 03:40 AM   #9
78mach1's Avatar
78mach1 is on a distinguished road
Send a message via MSN to 78mach1
you should take the hole strut out and then find someone with a mcpherson spring compressor, get it in the compressor and break it loose with a impact, then compress the spring and then take the nut off all the way
that way the hole strut/shaft doesnt turn inside the housing
Old November 25th, 2007, 03:41 AM   #10
78mach1's Avatar
who the hell brings it to autozone?.......they will try to sell him a damn o2 sensor!
Old November 25th, 2007, 03:47 AM   #11
JohnC's Avatar
1997 Mustang GT
13.56@102.94
That doesn't seem possible without removing the caster camber plates. And I'm not positive the shock would fit through that either. The bottom has that flange for the two lower bolts that would have to fit through the top.
If it will come out the top and I do that, I'll have to take it back to the shop to have the caster/camber plates set up again.
1997 Mustang GT
My Garage
Old November 25th, 2007, 03:58 AM   #12
78mach1's Avatar
no you unbolt it completley then pull down the a arm down and it comes out the bottom.....i replace struts at my work on a weekly basis
you can mark the plates, and the buttom strut bolts
but it might just be easier to re alighn if after
Old November 25th, 2007, 04:01 AM   #13
78mach1's Avatar
we always do an alighment right after we do a set of struts........but thats the easiest way
Old November 25th, 2007, 12:04 PM   #14
Resident Bubblehead
00vabchgt's Avatar
uhh, actually i did the first time i did my springs. i took it in and told them all i needed was for them to hit the nut with an impact. i didn't have one at the time. if you tell them exactly what you need, they don't try to sell you shit you don't need. try waslking into an autozone with out a clueless look on your face and i'm sure you'll do fine...
Military Crew
MM1 (SS)
US Navy Veteran
Old November 25th, 2007, 07:31 PM   #15
78mach1's Avatar
he could go to a tire shop (discount, les shwab) and they would do the same thing
Old November 30th, 2007, 01:11 PM   #16
Hourofpain's Avatar
2005 Torrid Red GTO m6
Hourofpain will become famous soon enough
and charge him fifty bucks for labor lol
Threads Similar to: Best Way To Get Top Shock Nut Off?
Shock Tower Brace 06GTMustang89 2005 - 2010 1 November 12th, 2007 05:04 PM
Shock questions dadslx 5.0 Mustangs 3 September 8th, 2007 02:44 AM
shock nstall jersey98gt 96-98 5 July 29th, 2007 08:54 PM
What is a good strut and shock set to use. nasty92LX 5.0 Mustangs 2 July 20th, 2007 12:06 AM
Shock type shurb125 5.0 Mustangs 1 January 18th, 2007 12:10 AM
