fuel cuts out car completely/then kicks back in
Old August 20th, 2006, 11:34 AM   #1
bobs86 is on a distinguished road
i have changed the gas filter on this 86gt....am lost as to what to do next.
what about fuel regulator? should i have it hooked up to dyno to find out
for sure?
starts fine..drives great...cuts out completely....cuts back in...
Old August 20th, 2006, 12:24 PM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Are you sure its fuel?
Old August 20th, 2006, 12:37 PM   #3
i guess i'm not totally sure...went easiest route without dyno.
have you heard of other causes with simular problems?
Old August 20th, 2006, 07:07 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You can put a fuel pressure gauge on to monitor fuel pressure when it happens again. If the fuel pressure drops then you know its fuel related. If it doesn't drop then it is something else. Other possible issues could be wiring, bad ground, ignition module, coil.
Does it cut out right away or does it usually happen after you drive for a period of time? If it happens after you drive for a while, how long of a drive? Does the car shut off completely or just spit and sputter a bit?
Old August 20th, 2006, 08:21 PM   #5
thanks............it's drives for awhile say 2 or 3miles/cuts out completely.
coasting along i'll down shift and it will kick in and go for awhile again.
repeating this process several times over 10to 15mile trip
Old August 20th, 2006, 08:32 PM   #6
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
Do you have an antitheft device?
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old August 20th, 2006, 08:34 PM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Sounds like a possible bad ignition module.
Old August 20th, 2006, 09:59 PM   #8
Thanks ..........oh by the way your stang is awesome!!!! Thanks i will check that, how much do those run$$ roughly?
Old August 21st, 2006, 12:11 AM   #9
stang fanatic's Avatar
stang fanatic is on a distinguished road
around 50 at most any auto parts
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old August 21st, 2006, 05:11 PM   #10
just drove it to garage...guy got in drove over 20miles/NOTHING HAPPENED. Damn, i know it's going to happen later....oh well thanks
for all the info.
Those are stock shorty headers on 86gt correct? Need to switch to mass
air also.
Threads Similar to: fuel cuts out car completely/then kicks back in
The completely boring asian thread El_Cangri The Clubhouse 15 October 19th, 2007 10:10 PM
Is it ok to run MSD 8.5 wires on a completely stock 5.0? MonsterSD 5.0 Mustangs 7 June 12th, 2007 04:29 PM
94 ford mustang surges at idle and cuts out when push gas akahoops 5.0 Mustangs 5 February 18th, 2007 03:31 PM
Any spoilers that don't look completely tacky? Compy386 V6 Mustangs 4 January 25th, 2007 11:09 PM
Ok so this is gonna sound Completely stupid Kope V6 Mustangs 5 December 9th, 2006 11:19 PM
