Squeaking On Passenger Side
Old November 13th, 2007, 02:50 PM   #1
greygunner's Avatar
greygunner is on a distinguished road
Ok, ever since i purchased my '01 v6 I have been experiencing a quite annoying high pitched squeak from the passenger side front wheel well. It is loud enough to be heard inside the car with windows up, but only at low speeds, like in a parking lot for instance. I have taken it to my mechanic who said it was either the tie rod or ball joint. He just called me and said the tie rod looked fine, so he was going to replace the ball joint. I have seen the thread and the fix for replacing the sleeves that seemed to be causing the squeaking for some. So, i guess my question is. What do you guys think is more probable, the ball joint being bad or rusted, or the sleeves needing replaced. I do trust my mechanic, just wanted to get the opinion of you guys because I also value your knowledge on the subject. again, it's a 2001 with just over 90k.
TIA
Old November 13th, 2007, 03:22 PM   #2
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
that could be a lot, maybe the ball joint possibly a wheel bearing. Your best bet is probably just let your mechanic take care of it
NCMM #9
Old November 13th, 2007, 04:38 PM   #3
dark-samurai2 is on a distinguished road
Send a message via AIM to dark-samurai2
to me it sounds more like it could be your water pump. more often than not a squeaking noise is usually the alternator. but because you said its coming from more on the passenger side i would say your looking more at the water pump
Originally Posted by Onemanzu
their is enough room for a skinny white kid to stand in their... you can make a lil turbo fit
Old November 13th, 2007, 05:06 PM   #4
tsp_2177's Avatar
2005 Civic
GAY!
tsp_2177 will become famous soon enoughtsp_2177 will become famous soon enough
but it's at low speeds wouldnt a water pump or alternator squeal all the times?
slow car member twinky times two
the stangs gone
pypes mid muffler catback with their X-pipe
In the top 20 cool peoples list on MM
potsticker in training
Old November 13th, 2007, 05:55 PM   #5
greygunner's Avatar
I appreciate the input guys, I am picking the car up tomorrow morning and I will let you all know the result of the ball joint replacement. I hope it gets rid of the sound.
Old November 13th, 2007, 09:45 PM   #6
MM's Resident Ricer
2006 Scion tC
13.001@113
if it is in the engine bay it probably is a belt that is alittle off they will stop squealing once you get up to speed, if it is from the suspension it could be a couple things.
NCMM #9
Old November 15th, 2007, 07:16 AM   #7
greygunner's Avatar
UPDATE: I got the car back yesterday evening. The ball joint was replaced and the squeaking is gone!
For the future reference of others, this was a very high pitched squeak that was coming from the wheel well and could be heard only when the wheel was turned and it could be heard while the car was off, at idle, or at low speed.
Old November 15th, 2007, 09:35 AM   #8
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
Ball joint i had the exact same issue. had it replaced and all is well. my bearing ended uo being bad as well.
Threads Similar to: Squeaking On Passenger Side
Sound from front passenger side RandoGT General Tech 5 November 16th, 2007 04:55 AM
removing passenger side o2 sensor zimaad 96-98 15 October 24th, 2007 12:10 AM
squealing from the rear passenger side.. VIXEN_GT 99-04 2 July 17th, 2007 06:59 PM
passenger side fender punkafi888 Visual 4 February 13th, 2007 01:01 PM
