Every 250 Miles or Weekly (whichever occurs first)
Check engine oil level
Check engine coolant level
Check windshield washer fluid level
Check brake fluid level
Check tire wear and psi
Every 3,000 Miles or 3 Months (whichever occurs first)
all items previously listed plus:
Check power steering fluid level
Check automatic transmission fluid level
Check engine oil and oil filter
Check clutch pedal freeplay
Every 6,000 Miles or 6 Months (whichever occurs first)
Check and service battery
Inspect and replace windshield wiper blades
Rotate tires
Check seatbelt operation
Every 15,000 Miles or 12 Months (whichever occurs first)
Inspect and replace underhood hoses
Inspect cooling system
Check fuel system
Inspect steering and suspension componenets
Inspect brakes
Check manual transmission lubricant level
Check rear differential lubricant level
Every 30,000 Miles or 24 Months (whichever occurs first)
Check engine drivebelts
Inspect ignition system components
Replace air filter
Check PCV valve
Replace fuel filter
Inspect exhaust system
Change automatic transmission fluid and filter
Service cooling system
Change brake fluid
Every 60,000 Miles or 48 Months (whichever occurs first)
Replace spark plugs
Change manual transmission lubricant
Change rear differential lubricant
Recommended Fuel
All except Cobra- unleaded 87+octane
Cobra- unleaded 91+ octane
Engine Coolant
50/50 mixture of ethylene glycol antifreeze and water
Brake Fluid
Dot 3 or Dot 4 brake fluid
Differential Lube
80W-90 Lubricant; for trak-lock axles: add 4oz of friction modifier when changing oil
Fluid Capacities
Oil Capacities
3.8L V6- 5qts
4.6L V8 (-1996)- 5qts
4.6L V8 (1997+)- 6qts
5.0L V8- 5qts
Fuel Capacity
15.4 gallons
Cooling System Capacities
V6- 11.8qts
V8- 14.1qts
Automatic Transmissions
AODE- 12.5qts
4R70W- V6- 13.9qts; V8- 12.8qts
Manual Transmissions
T5- 5.6qts
T45- 6.6qts
Rear Differential
7.5"- 3.25pts
8.8"- 3.75pts
Ignition
Firing Order
Spark Plug Gap
.052"
Torque Specs
Wheel Lug- 85-105 ft./lbs
Spark Plugs- 7-14 ft./lbs
Oil Pan Drain Plug- 8-12ft./lbs; '98 V8- 15-19 ft./lbs
Auto Transmission Pan Bolts- 10-12 ft./lbs
Manual Transmission Drain/Fill Plug- 12-22 ft./lbs
Rear Differential Drain/Fill Plug- 12-22 ft./lbs
Source: Haynes Manual and a Ford Mustang blog.
Rotate tires
Check fuel system
Inspect brakes
Replace air filter
Check PCV valve
Replace fuel filter
Change brake fluid
Replace spark plugs
Recommended Fuel
Engine Coolant
Brake Fluid
Differential Lube
Fluid Capacities
Oil Capacities
3.8L V6- 5qts
5.0L V8- 5qts
Fuel Capacity
15.4 gallons
V6- 11.8qts
V8- 14.1qts
AODE- 12.5qts
T5- 5.6qts
T45- 6.6qts
Rear Differential
7.5"- 3.25pts
8.8"- 3.75pts
Ignition
Firing Order
Spark Plug Gap
.052"
Torque Specs
