Help! New Tires Trashed!
I have a 1996 Mustang GT Convertible. I installed Cobra 17 X 9 Wheels and new tires. I added 2" rear wheel spacers and a sub box with 2- 10" & a amplifier to the trunk. I believe the suspension is all original & wore out. The car is coming down on the tires at some point & the fender wells have cut my new tires to pieces. They are trash now & I have got to buy 2 more rear tires. I don't want to remove the wheel spacers because the rear tires look like they are tucked under the car & closer together than the front tireswithout them. I want to fix the problem before I go buy 2 new tires. Anyone have some suggestions?????????
Need to be Quick!!!! |
did you try removing the heavy sub box and amp?
Lois: I guarantee you a man made that commercial. Peter: Of course a man made it. It's a commercial Lois, not a delicious thanksgiving dinner. |
Well, The problem is I am not sure when it is doing it to be able to check it. It may be Bumps, It may be on uneven surfaces, It may be when under accellaration. I am not sure. I am wondering if Springs, Coil Overs, or Adjustable Lower Control Arms would solve this problem and keep the back end from dropping down but I still want it to handle good.
You may need to go with a smaller spacer. I have a 1.5" spacer in the rear and it looks so much better and no problem with rubbing. if your using a 2" spacer and wide tires its going to rub you either need less wide tires or a slightly smaller spacer.
![]() 95 Civic Ex, FnF1's, Morimoto Mini h1 retrofit, GSR, bbk intake, BDL tb, 57trim t3/t4 8psi, 297whp 96 Civic Ex 2dr, G3 HID retrofit, FnF type 1's, Si cluster, Obd1 Z6 swap |
just buy a 10.5 wheel for the back and don't use spacers... they aren't always reliable
2000 V6 Performance Red @ Cardomain Was fun but a waste... 1987 LX Hatch | Soon to be a 600hp monster |
spacers are dangerous
#7 | |
1999 Mustang GT
14.2 no mods, bald tires
![]() iTrader: 1 reviews
P.S. IMHO I wouldn't recommend spacers to anyone, they aren't reliable and they're dangerous. I suggest that you get wider wheels and tires to be on the safe side and it gives your car a more aggressive look with the bigger meats on the back!!!!!!!! |
cut the wheel well make em fit!!!
I'd throw the spacers in the garbage before they come back and bite you in the ass. Wide wheel spacers are dangerous.
I took them off and replaced the tires for the time being. I am going to rework the suspension and then worry with the stance look. My interests are divided right now. I am looking at buying a 86 SVO in mint condition with a 4 cyclinder beefed up to 300HP.
1999 Mustang GT
Well, good luck with that.
yeah I agree buy wider rims, it would be a lot safer
1991 LX Mustang
Or Roll the fenders with a basball bat to get the look you want
Threads Similar to: Help! New Tires Trashed!
| Trashed the T-45... now what are your suggestions? NEW STUFF | Slowbra_12 | 96-98 | 3 | October 4th, 2007 01:14 AM |
| Unbelievable - Body Kit Is Trashed | fallstar01 | Visual | 19 | March 25th, 2007 03:40 PM |
| Trashed 99 Cobra Block | whitesnake | Modular Mustangs | 6 | February 28th, 2007 04:07 AM |
| Nankang Tires? Republic tires? | Mr.Chips | V6 Mustangs | 1 | January 19th, 2007 05:33 PM |
| T5 Trashed | 1gunner23 | 5.0 Mustangs | 10 | May 1st, 2006 12:48 AM |
