Engine Surging @ Idle
Old August 22nd, 2006, 02:56 PM   #1
Milner62 is on a distinguished road
Ok I've done all i could aside from pulling the water pump and replacing the timing chain.
The engine idles great in park but has a slight miss and when in gear it idles fine when driving but when you stop once the engine is warmed up it surges and shakes.
I was thinking about adjusting the rockers, but i read that in 78 the 351 windsors had unadjustable rockers is this true?
Also what are the chances that this could be the rockers needing to be reset after 160,000 miles and not the timing chain worn?
Has a new carb, new ign coil, new cap and rotor, brand new sparkplug wires, same old plugs but i did reset the gap wider to 1 over the min factory gap rating on the emission decal it was way less than that. it ran smooth in idle and surged in park.
So what spark plug gap is recommended and ill post the gap range and the gap im running now after i replace the ps hose today.
Threads Similar to: Engine Surging @ Idle
engine surging chickenbot 5.0 Mustangs 13 November 13th, 2007 01:31 AM
surging idle help jam77 5.0 Mustangs 7 August 20th, 2007 06:45 PM
New Owner - Engine Idle prossett 94-95 1 February 10th, 2007 08:26 PM
Engine Idle Is Sporadic! Please Help cboman777 5.0 Mustangs 13 October 9th, 2006 04:10 PM
Engine surges at start and idle fluctuates 200KMILES V6 Mustangs 2 May 3rd, 2006 06:23 PM
