10 Power Killers & How to Avoid them
Old December 1st, 2007, 01:09 PM   #1
TurboLX's Avatar
1988 Mustang LX Turbo
(1) Blown Header Gaskets - Every stock car that goes into the corner with flames coming out of the exhaust, every drag car that pops after the finish line, has the same problem, they all have an exhaust leak. The amount of power lost depends on the location of the leak – before the collector is worse than after. The most critical location being at the header flange. Use liquid Teflon on both sides of the gaskets and tighten them every week – you won’t have any more problems.
(2) Overfilled Oil Pan - With a properly located oil pump pickup most engines don’t need more than 5qts of oil. Want to see how critical oil level is to power? Test it: If you have an 8qt pan, run it with both 5 and 8. If it’s a drag car where it’s easy to see power changes, you’ll be shocked – the difference may be as much as 3 tenths of a second. Not only is there more power with less, but there’s also less chance of air mixing with the oil – which I’m sure you understand is a bad thing.
(3) Dirty Air filter - I’m embarrassed to admit it, but I’ve actually been tripped up by this one. It never crossed my mind that a dirty air filter could be the problem when I chased a bog in the car for weeks. I was using an oil impregnated air filter and was having the car painted. I’m sure all of you body guys know the amount of dust that is involved, how much of it ends up under the hood and exactly where it went when I fired up the engine. I had bought into the advertising on how long that type of filter was supposed to last before cleaning. Pretty dumb on my part. Anyway, I know it’s simple, but sometimes that’s just the thing that will trip you up.
(4) High Coolant Temp - It’s not the coolant temp itself that’s the problem, it’s the temp of the passage air must pass through. From a performance standpoint, it’s almost impossible to have the intake and heads too cold. Ever see the guys putting ice on their intakes? That’s taking it to the extreme. Now on the other hand, the bottom of the engine does need some heat, including the oil. Just remember, cold on top, hot on the bottom.
(5) Rusty Header Tubes - I watched a racer chase a miss in his car for half a season. Rust inside the headers ended up being the problem. I would have never believed it had I not seen it. I know a lot of you are thinking, just get the headers coated and there won’t be a problem. Wrong! These coatings do nothing to protect the inside of the tubes. Even if they were able to properly coat the insides, the heat would burn it off in a hurry. The best choice is a stainless steel header, the next best is to clean out the rust in the off-season - sandblasting being the easiest method.
(6) Engine Driven Fan - This can be the biggest power killer on the front of the engine. An aftermarket flex fan doesn’t help much either – do this test: take a flex fan and see how much effort it takes for you to straighten out the fins. That should give you a good idea the amount of work the engine must do to drive the fan. An electric fan is the best option, but you can also try a fan clutch or a flex fan with a shallow blade angle.
(7) High Inlet Temp - Everybody knows the cooler the weather, the better the car runs. The better way to look at it though is the cooler the air reaching the engine, the better the car runs. If you pull air from under the hood, you might be shocked to find out how much higher the temp is than outside the car. Any modification that brings cold air to the engine will make a measurable difference in performance, that is, as long as it’s not flow restrictive.
(8) Ineffective Cowl/Hood Scoop - The object is to not only bring cold air to the engine, but to create more pressure in front of the induction system to allow the engine to more easily pull the air/fuel mixture in. It’s hard to screw up a forward facing hood scoop, but having it too low, too small or too far back from the front of the car can hurt. The cowl hood is not nearly as forgiving. Some of the things to watch are the height of the front of the car and how closely the cowl comes to the windshield. Want to get trick? Do what the big guys do, use a manometer to find the combination that gives the highest pressure.
(9) Weak Valve Springs - Are you installing a bigger cam, higher ratio rockers or revving the engine harder? Think you’ll make more power? Maybe not if you don’t address the valve springs. If your engine goes flat at upper RPMs or during teardown you notice the valve’s keeper grooves are beaten up, you may need more spring pressure. Of course you could always rent some Spin-Tron time and find out for sure, but I’m sure that fits most racers budgets. Many of the cam designers and valve spring manufactures have this testing device. Find out which do and take their advice.
(10) Misadjusted Lash - The proper lash for your cam is dictated by the cam design. The cam designer is basically trying to get the valve to open and close as quickly as possible without bouncing on the seat when it closes. A balance between these two desires is where the most power is made. With the amount of time I’ve spent Spin-Tron testing and now that I’m getting older and less aggressive, I’ve become a real fan of tighter lash. If you don’t need that last couple of horsepower, keep the lash at the cam designers spec or tighter – your valvetrain components will thank you.
Old January 27th, 2008, 05:47 PM   #2
Achieving more N/A power!
gills99stang's Avatar
When this baby hits
88 miles an hour...
gills99stang will become famous soon enoughgills99stang will become famous soon enough
Send a message via AIM to gills99stang
Good stuff!
Brendan
'99 Mustang GT [ 318 rwhp N/A ] - SOLD ()
'04 F150 XLT SuperCab
Old February 6th, 2008, 08:42 PM   #3
79Capri302's Avatar
1979 Capri GHIA
79Capri302 is on a distinguished road
i've been around engines of gas and diesel design for a few years now and i even learned a thing or two from that. nice job!
Old February 24th, 2008, 09:38 PM   #4
jdrahush's Avatar
jdrahush is on a distinguished road
good advice thanks.
Old May 24th, 2008, 06:43 PM   #5
1998 MUSTANG GT
EVILSIDER is on a distinguished road
Awesome write up!
Old June 15th, 2008, 12:15 AM   #6
deetz03's Avatar
2001 Mustang GT
deetz03 is on a distinguished road
great stuff, the explanations are really well thought out
2001 Laser Red Mustang GT - All Show, No Go...yet
19" Zenettis, H pipe with flowmasters, Optima Red Top
Old June 22nd, 2008, 02:42 PM   #7
1999 cobra
13.00
98srsmustang is on a distinguished road
nice work
Old June 29th, 2008, 10:47 AM   #8
superbeef1000's Avatar
sounds like i better fix my 02 sensor and massive header leaks ,,it felt a lot slower as the header leaks came on but did not think it was from this,,,good post
Old August 29th, 2008, 12:07 PM   #9
02blowngt is on a distinguished road
Wink
post
+1 good post
Old December 7th, 2008, 10:40 AM   #10
Asdrubael's Avatar
unknown
Asdrubael is on a distinguished road
Excellent advice, thank you.
"In God we trust, all Others we monitor"
Old December 17th, 2008, 10:04 PM   #11
LightDude is on a distinguished road
That's nice.. i've been looking for those tips.. thanks for putting them here..
HID Lights
Old March 8th, 2009, 07:30 AM   #12
jbracefan1977 is on a distinguished road
these tips will come in handy! thanks
Old March 8th, 2009, 07:42 AM   #13
mylilboostedpony's Avatar
2001 Mustang GT
mylilboostedpony will become famous soon enough
Send a message via AIM to mylilboostedpony Send a message via MSN to mylilboostedpony
good job!
Отряд милиции особого назначения
White Mustang Crew Co-Founder
Old February 24th, 2010, 06:57 AM   #14
2000 Mustang GT Convert
rthouck is on a distinguished road
nice post - thanks
Old March 10th, 2010, 02:42 AM   #15
zsvrsn3 is on a distinguished road
good job
Old March 11th, 2010, 11:45 AM   #16
Adrenaline Racing's Avatar
1999 Mustang Gt
idk
Adrenaline Racing is on a distinguished road
Send a message via AIM to Adrenaline Racing Send a message via MSN to Adrenaline Racing Send a message via Yahoo to Adrenaline Racing
Thanks i just got a cowl hood didn't know that about them.
Old July 5th, 2010, 07:58 PM   #17
2008 GT
SilverBack is an unknown quantity at this point
Great Job
Threads Similar to: 10 Power Killers & How to Avoid them
Follow up to import killers questions JASonic V6 Mustangs 13 May 20th, 2007 11:25 PM
mustang blue paint helps avoid tickets??? JASonic V6 Mustangs 13 May 11th, 2007 09:35 AM
NEED MORE POWER criptez V6 Mustangs 20 May 5th, 2007 05:09 PM
Max power Racerchik02 V6 Mustangs 27 April 28th, 2007 08:19 AM
more power burin_rubber V6 Mustangs 14 February 22nd, 2007 09:01 PM
