I have a 2002 V6 automatic and the shifter is stuck in park. I can crank the car up, turn it back one click shift into neutral and crank it back up from there and change gears normally. It's only when I put it into park it gets stuck. Im not very good with cars and all of it's parts but I did check the fuses for the shifter interlock which i believe are fuses 17, and 35. Both of them are good. I'm not sure what it may be that has it locked like that. Btw my tail lights do work when I press on the breaks.
If any of you have an advice on how to fix this problem, I would appreciate it
