Okay fellows and gals. Need help. My sail panel was damaged in a storm and I need to replace. I have already purchased a used sail panel and window but not sure how to remove. Would it be better just to take to body shop and have them replace or is this something I can handle myself.
It is held in place from the backside. You have to remove the interior trim around the window to acess them. IIRC there is a screw or two (might be a pushpin) behind the door seal as well that has to come out. And the trim above the window has to come off as well as it fits into a recess at the front of the sail panel.
Unfortunately i do not have anything other than that to offer. I thought i seen a write up, but cant find it.
---------- Post added at 04:32 PM ---------- Previous post was at 03:51 PM ----------
I found a little.
And this popped up here on MM. Some of the pics are missing but still useful. If youre not replacing the window you can skip some of it.
Related Threads
Modded Mustang Forums
6.3M posts
80.3K members
Since 2005
