How to: side gapping spark plugs
LinkBack (13) Thread Tools
Old December 25th, 2007, 12:08 AM   13 links from elsewhere to this Post. Click to view. #1
TurboLX's Avatar
1988 Mustang LX Turbo
First, obtain a high quality over the counter version that carries an economical price. Motorcraft and Autolite come to mind for their performance and safety features of inherently melting before the piston does. Then carefully shorten the electrode arm by taking a die grinder with a small cut-off wheel and remove a small portion from the end. *Do not* nick any part of the center electrode or porcelain! As seen in the photos below, nearly the entire center electrode can be seen from the bottom of the plug as compared to the standard version being completely shrouded from view. This modification will expose more of the generated spark to the combustion chamber, thereby more completely igniting the air/fuel charge instead of the spark being forced to propagate in a sideways direction and not directly into the majority of the combustion mix. This procedure of exposing the electrode is called "Side Gapping", and has been a well kept secret for many years in the racing circles. While some may debate the amount of Horsepower, Torque & Fuel economy increases, there is no disputing that side gapped plugs significantly improve spark propagation as well as reduce plug fouling and loading up, with no sacrifice to your wallet.
The sharper edges also encourages the spark to ignite quicker and stronger, much like striking an arc with a welder on an edge rather than a flat surface. However, there is one minor drawback, and that would be the center electrode will wear one side sooner due to the spark now being directed to one specific area on the plug edge, rather than a random path all around the electrode point. Even though the plugs may wear slightly quicker, since your home-modified plugs can cost up to four times less than that of "premium" versions, they can be more readily changed, leaving you with fresh new plugs during your engine's operation more of the time than with the costly premium versions.
As the photos show, the side gapped plug exposes more of the spark path to the open combustion chamber than the Standard version, as well as even the Splitfire® or Bosch+4® types. And this can be done to any of your favorite brands of plugs you already like, to make them better!
To gap the new plug, slide the feeler gauge in at a 45 degree angle to read the tightest clearance between the center electrode and the arm. Slightly tighter than OEM recommended gaps can be taken advantage of, measuring the actual space between the closest surfaces of the two electrodes. Reduce gaps by approximately .010". Closer clearances will yield the same if not more of the spark front, and at the same time resist the flame from being "blown out" when using Nitrous Oxide injection or supercharging. The closer "sharp edged" surfaces will more easily propagate the initial spark while the main mass of surface area being farther away, will increase the spark travel (volume). Re-gap periodically, as the accelerated wear on the electrode edges will increase the gap sooner.
NOTE: Side Gapping spark plugs has been the serious racer's secret since the early 60's. Only recently have major manufactures started producing this style of plug for mass production, but with unreproducible sophisticated designs, since if their expensive plugs looked like these, they would lose all their business to home mechanics copying that simple to do at home design. Experiment with different configurations and… Have fun!
PHOTO: ……...The left photo illustrates the shrouded standard type plug (red arrow) "squeezing" the spark sideways rather than downwards directly into the homogenized combustion mix in the cylinder such as the newly modified Side Gapped version does (yellow arrow). The Yellow graduation shows how much of the arm that was cut off. The right photo compares three types of plugs. Note the center electrode exposure the combustion chamber sees.
HOW SIDE GAPPING WORKS: The closer gap (1-Yellow) allows for easier ignition while the angled surfaces (2-orange) allow the ignited spark to grow in size to exceed that of normally shaped plugs. As the spark column flows along the electrode surface it grows outwards in size towards the combustion chamber and down towards the piston (3) creating a larger spark presence but with an easier starting spark for situations where more spark is needed, such as high compression cylinders, high rpm's and increased fuel conditions as well as preventing "spark blow-out" in nitrous and super/turbo charging applications.
Old December 25th, 2007, 12:43 AM   #2
1990 GT
bigdawg is on a distinguished road
I remember watching Chris Tuten do this, and asking what the hell was he doing. I thought he was seriously cutting his electrode off. Then he said he was making his own splitfire plugs. Which I thought were a gimmick as well. Good post.
Old January 11th, 2008, 12:28 AM   #3
JBIGBOOTSY's Avatar
1990 LX hatch
Radius tipping is also a good practice
Old January 14th, 2008, 08:47 PM   #4
WAR-PARTY's Avatar
2001 YUGO GT
WAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of light
Ya back in the 70s we made split gap plugs, all that was need was a jewlers saw and a little time, oh la 80 cents not 6/7 bucks or what ever split fires sells them for.
Old February 6th, 2008, 08:49 PM   #5
79Capri302's Avatar
1979 Capri GHIA
79Capri302 is on a distinguished road
amazing, see the things we learn? i feel smarter just for joining up
Old July 3rd, 2008, 04:01 AM   #6
Compspeed502's Avatar
GT Clone
Compspeed502 is on a distinguished road
lol, I was doing this on my 83 dodge shelby turbocharger, way back in the day. I like when old school tricks is used with new school technology, I also remembering the sleeve trick, which is alot harder to do, involves cutting the entire arm off and welding a premeasured cone over the electrode with the end of the cone cut off, to expose the electrode, to get the same, or maybe alittle better spark, without as much wear on the electrode.
Old December 8th, 2008, 10:36 PM   #7
Asdrubael's Avatar
unknown
Asdrubael is on a distinguished road
I'm gonna try this when I get home. Good post man...
"In God we trust, all Others we monitor"
Old December 10th, 2008, 09:33 PM   #8
2000 Mustang v6
winnie51189 will become famous soon enoughwinnie51189 will become famous soon enough
Send a message via AIM to winnie51189
what if you grind the end to a point while you at it will that net a gain or loss?
Old July 11th, 2009, 09:26 AM   #9
Ke^in's Avatar
Ke^in is a name known to allKe^in is a name known to allKe^in is a name known to allKe^in is a name known to allKe^in is a name known to allKe^in is a name known to all
Turbo seemed to have a lot of good info. Too bad he was banned.
I like to go to Subway because the women there have to make ME a sandwich.
Old February 24th, 2010, 05:58 AM   #10
2000 Mustang GT Convert
rthouck is on a distinguished road
why was he banned?
Old April 8th, 2010, 12:45 PM   #11
stuf221 is on a distinguished road
dunno.
Old July 23rd, 2010, 02:29 PM   #12
rabasujuly0110 is on a distinguished road
hello guys ...
its really nice and informative post....
i just liked it....
thanks for your information guys ...........
Old August 5th, 2010, 01:50 AM   #13
2006 Mustang GT
sphinx is on a distinguished road
This isn't quite the right place for this, but I just bought an 02 mustang GT and was giving the engine a good once over. When I went to check the spark plugs the bolt holding on a coil pack wouldn't unscrew. I think the previous owner may have striped the nut or something, is there any way I can get it out to change my plugs without breaking anything?
Old August 23rd, 2010, 12:01 PM   #14
89 Mustang GT
my daily ride produces 28,984 lbf of thrust
89fiveohhh is on a distinguished road
nice i will have to try this out when i get home
LinkBack to this Thread: http://www.moddedmustangs.com/forums/general-tech/47961-how-side-gapping-spark-plugs.html
Kawasaki Bajaj Rouser 200cc / 220cc - Version 36 - Page 7 - Motorcycle Philippines - The #1 Motoring Enthusiast Community in the Country This thread Refback December 23rd, 2010 07:52 AM
Kawasaki Bajaj Rouser 200cc / 220cc - V.25 (KBR200;220) - Page 10 - Motorcycle Philippines - The #1 Motoring Enthusiast Community in the Country This thread Refback September 30th, 2010 01:09 AM
Kawasaki Bajaj Rouser 200cc / 220cc - V.25 (KBR200;220) - Page 10 - Motorcycle Philippines - The #1 Motoring Enthusiast Community in the Country This thread Refback September 30th, 2010 12:28 AM
Kawasaki Bajaj Rouser 200cc / 220cc - V.25 (KBR200;220) - Page 10 - Motorcycle Philippines - The #1 Motoring Enthusiast Community in the Country This thread Refback September 30th, 2010 12:12 AM
Timing and Ignition - Ford F150 Forum - Community of Ford Truck Fans This thread Refback May 31st, 2010 05:16 AM
Moped Army - Re: New exhaust and spark plug ?? This thread Refback August 24th, 2009 08:10 AM
This site has gone nuts... - V6Power Messageboard This thread Refback July 15th, 2009 07:17 PM
This site has gone nuts... - V6Power Messageboard This thread Refback July 15th, 2009 06:35 PM
This site has gone nuts... - V6Power Messageboard This thread Refback July 15th, 2009 06:31 PM
This site has gone nuts... - V6Power Messageboard This thread Refback July 15th, 2009 06:10 PM
Police CB650PZ This thread Refback May 6th, 2009 11:11 PM
Police CB650PZ This thread Refback May 6th, 2009 08:03 PM
Everything about splitfire spark plug - Yahoo! Glue This thread Refback February 23rd, 2009 12:36 AM
Threads Similar to: How to: side gapping spark plugs
Spark Plugs soccerboy08 V6 Mustangs 1 November 22nd, 2007 12:49 AM
What spark plugs homeboy2kfun V6 Mustangs 2 November 13th, 2007 12:21 AM
Spark Plug Gapping? SantanielloITA V6 Mustangs 20 November 10th, 2007 07:44 PM
Gapping my plugs?? Bossman 2005 - 2010 1 January 29th, 2007 07:27 AM
What should I be gapping my plugs at? sum_weirdo 5.0 Mustangs 3 January 24th, 2007 10:53 PM
