1987 Mustang GT
How do you change a pulley on a cent s/c
do the pullies just come off or do you need a puller? I have a paxton novi s/c and I need to change the pulley. How about putting them back on? Not sure I would want to take an impact wrench to my supercharger but im not sure.
Look Ma! My First Post!
the bolt may come loose with a spanner if you leave the blower belt on. then it may require a puller. mine did.
48.47@ 12.58
^ welcome to the forums.
keep it classy San Diego.
Threads Similar to: How do you change a pulley on a cent s/c
| new pulley | chozen1 | 2005 - 2010 | 7 | August 8th, 2007 12:06 PM |
| Pulley change? | Exseque | 2005 - 2010 | 1 | March 25th, 2007 06:42 PM |
| vortech pulley change | 2001bullitt | 99-04 | 3 | January 19th, 2007 12:09 AM |
| ud pulley 04 | kanniiee | V6 Mustangs | 5 | July 28th, 2006 11:15 PM |
| UD pulley came in!!! | 00SoSlow | V6 Mustangs | 4 | April 4th, 2006 05:10 PM |
