vortech ?s
alright just recently added the s/c runs great , but when i stomp the gas from low rpms there seems to be a hesitation in the boost. almost feels like a rev limiter and then it will kick in hard, not a belt slipping. is this a tune problem ????? anyone with this problem ?
thanks in advance Gates
2004 40th anniversary gt vortech v2 bbk off road x pipe 2.5'' flowmasters eibach sport springs termi hood termi front bumper more to come......... |
muneris pro ego
the vortech is a centrifugal (spelling?) supercharger so it builds boost similar to a turbo. it has some lag time as opposed to a roots or twin screw s/c. you are feeling the lag time then the boost kick in
Buy my M90 Kit and my Gears and T-Loc! MM ZDC - Alaska Base Commander MM+ Cleavage Club #24 MM Cares Crew / Military Crew M2C2 President / USCG - OS2 ![]() |
2002 Chevrolet Impala
I have a friend who has a whipple and he had that problem a while ago. He figured out later it was the tune and took his car to another shop to get it retuned. Now it runs great.
MasterDeBater
I'm with coastie.
Prob just a lil' lag. unless it just started
Join The MM Facebook: Modded Mustangs Facebook Vote For Modded Mustangs Ride of the Month Eskimo Brothers To Smooth: Safi, Blitz34, Graystang01, WillTheThrill, Bwal |
1987 Mustang GT
I have that with my Paxton I think it's pretty normal
1993 Notch, 1988 Notch
It is normal, you have to move from vac. to boost, that period or "dead spot" is lag. You can tune a little better to help it, you can also re-cam and gear to compensate a little to help it as well.
Beyond that you will have to be patient the second it takes to move
RLY SRS
2004 Cobra
nature of the blower - all blowers I've owned did the same thing - centr. are higher end monsters.
How are you sure its not the belt slipping?
If its stumbling or doesnt seem to be pulling like it should... take a look at the boost gauge (assuming you have one), if the needle is jumping of moving back and forth.. it could very well be the belt slipping. If its a lag.. and thats what your experiencing.. and just describing it as a hesitation.. thats normal for that type of supercharger. You could band-aid that problem with a gear swap, and a more precise tune.
Threads Similar to: vortech ?s
| vortech v2 Kit | 02SCGT | General Tech | 17 | September 11th, 2007 10:58 PM |
| vortech with no fmu help | angermgt | 5.0 Mustangs | 5 | April 4th, 2007 11:02 PM |
| Vortech s/c | Garhfer | 99-04 | 4 | March 10th, 2007 07:05 AM |
| Vortech V2 sq | Brianzeke007 | V6 Mustangs | 6 | November 28th, 2006 07:07 PM |
| Vortech | mustangdrvr2019 | V6 Mustangs | 1 | September 25th, 2006 03:21 AM |
