Gauge Help
Old January 12th, 2008, 05:45 AM   #1
2006 mustand GT S.C
louie21668 is on a distinguished road
Gauge Help
I Just Installed A Whipple S.C And Need Some Gauges I Like Aem. Should I Buy Wideband Air/fuel And A Boost. Does Any One Know Of Any Other Gauges I Should Look At.thanks
Old February 21st, 2008, 10:48 PM   #2
bottlefed02gt is on a distinguished road
Oil pressure and fuel pressure
Old March 20th, 2008, 02:19 AM   #3
turbodgumby's Avatar
95 Lightning-Twin Turbo
10.66@126
turbodgumby is on a distinguished road
I would buy the wideband, an electric fuel pressure gauge, Boost gauge,oil press., and water temp gauges.
Old March 20th, 2008, 12:40 PM   #4
Trick Tuners's Avatar
KB'd GT
The most important is the wideband by far! Boost is good for trouble shooting, but usually will not help out much. Fuel pressure is good too, but the wideband will show a drop in fuel pressure and is much more accurate. I run dual widebands, EGT, boost, fuel pressure (mechanical with an isolator), IC fluid temp, intake air temp (up and down stream), and OBDII parameters, but I'm a data junkie! I have basic widebands for $260 like this
And the IMFD gauges that can display up to 4 parameters that look like this. The IMFD gauges can also flash white and red based on 4 user configurable warnings (like if boost >2psi AF must be less than 12:1 or flash warning)
IMFD gauges
Threads Similar to: Gauge Help
A/F Gauge 96GtGoodz 96-98 13 December 9th, 2007 01:47 PM
My New gauge pod! 97Cobra The Clubhouse 15 September 9th, 2007 05:35 PM
no gas gauge please help me itsmyfiveoh 5.0 Mustangs 5 May 22nd, 2007 10:51 AM
gauge set up joe 5.0 5.0 Mustangs 8 May 17th, 2007 09:12 PM
Gauge Pod chrish91286 V6 Mustangs 0 November 8th, 2006 07:39 PM
