1989 mustang LX
11.42 @120
How Much Boost?
I have a 89 hatchback that has a vortech T trim on it. right now im only running 7LBS of boost for now but I would like to up it. It is a 302 punched out to 306 it has forged internals with windsor jr. heads, 520 cam, ported and polished cobra intake, a 1 to 1 fuel pressure regulator. it has a SCT chip that has a custom tune on it. How much boost can I run. Also how much more boost can I run without messing up the tune to much.
89 hatch.....4,000 dollars..vortech supercharger kit.....3,800 dollars...built 306 windsor motor.....3,000 dollars beating a 75,000 dollar z06 corvette....PRICELESS UNTIL I SOLD THE CAR |
2004 Cobra
If you have all the good internals, you can boost up 13-15 lbs with no problem. I had both a t-trim and a 17 lb ic procharger with my 331 combo. You will def. have to retune with extra boost.
1989 mustang LX
11.42 @120
42 pound fuel injectors. and 255lph fuel pump. If i raised it 3 pounds would i need to retune
1987 Mustang GT
you running an inline pump to??
#7 | |
usually no
Didnt you ask this question in the 5.0 section?
1989 mustang LX
11.42 @120
yea i posted this one first but didnt get a response for a few days so i posted it in the 5.0 section
I think 42's will be alright with around 13psi, just make sure your Fuel Pres. doesnt drop off. I would highly recommend a new tune before you get on it at all after a pulley swap.
Threads Similar to: How Much Boost?
| Boost 101 | TurboLX | V6 Mustangs | 14 | April 29th, 2008 11:01 PM |
| how much boost? | 969800gt | 99-04 | 2 | March 21st, 2007 03:47 PM |
| Max Boost | g money | V6 Mustangs | 13 | February 11th, 2007 06:14 PM |
| how much boost??? | 9stang1 | 5.0 Mustangs | 5 | December 5th, 2006 05:32 PM |
| Turbo Boost vs Super Boost | droppedbass87 | General Tech | 12 | October 16th, 2006 09:56 AM |
