EGR Not Completing
Old September 16th, 2006, 11:13 PM   #1
mustangblk96 is on a distinguished road
EGR Not Completing
I have a 96 mustang gt that the EGR is not completing. Everything else is complete......I have replaced all the parts that run with the egr system and still the same thing. NOT COMPLETE!!!!!!! I check for leacks and couldn't find any and checked the hoses for cracks.
Is ther something else that I am missing to check?
I was told to take the egr off and check the hole there and see if it is cloged and to check the egr hose that goes down to the exhoust and blow it out.....
If anyone else knows something else to check let me know.....
Thanks alot guys... I will go out on sunday and do all this to the ride and see what happens...Later
Old September 16th, 2006, 11:55 PM   #2
AtlanticBlue99's Avatar
1999 Ford Mustang V6
14.79 @ 92.15
on your egr pipe from the headers to the pump on the block, you should make sure your 2 rubber hose lines are on the right ends. if you cross them up they wont work right. just a simple check. also, check the vaccuum lines from the dpfe to the block and the pump. is it throwing a CEL code, or is it just not hooked up? check the electrical connections too.
ModdedAutos
1999 Mustang V6
Old September 19th, 2006, 04:07 PM   #3
I already cleaned the egr hole out and and cleaned the egr line that goes to the headers. The line to the headers was cloged up and got cleaned out and and still nothing I was for sure that was it but it wasn't.
I didn't cross the hoses because there is a small one and bigger hose connector to plug up to. I gusse I will check the vaccum lines again and see what happens.. It's not throwing any codes it just says EGR system not complete. Let me know if there is anything i should check.. Thanks alot for the info....
Old September 19th, 2006, 04:44 PM   #4
14.79 @ 92.15
what says EGR system not complete?
ModdedAutos
1999 Mustang V6
Old September 19th, 2006, 11:00 PM   #5
yes, it says egr sytem not comlete....It's weired becouse there is no code on it....All it says is not complete on the egr system..
Threads Similar to: EGR Not Completing
EGR Not Completing mustangblk96 Modular Mustangs 12 September 25th, 2006 05:21 PM
