1988 Mustang LX Turbo
Engine Problems? (LOOK HERE)
1.) Check spark plugs - This is the first thing I tell
people to do if they think they've got a problem. Pull all your plugs out and take a look - it will be obvious if one cylinder is having a problem. 2.) Do a leak-down test - If you think your engine is down on horsepower a leak-down test may help you locate the problem. It will find blown head gaskets; broken or stuck valves; and bent or burned valves. If you're missing a lot of power you'll need to see over 20% leakage. 3.) Inspect oil filter - Same as your weekly maintenance. If bearing problems are caught early by checking the filter, you may save thousand of dollars in repairs. A spun bearing will give little warning - if you think there is a problem, check the filter (it will be obvious). 4.) Check drain plug - If you're at the track and don't have a way to inspect your filter, the next best thing to do is check the magnetic drain plug (You do have one, right?). 5.) Inspect valvetrain - Check the valve spring pressure; valve lash; look for broken coils on inner or outer springs; broken rocker arms; missing lash caps or; broken or bent pushrods.
1988 LX Coupe 2.5L, GT35R, 44mm WG, 32psi, C16. |
Quite Helpful. Can a seized engine be rebuild? I've been told to just buy a shortblock instead.
Is the 4.6L SVT cobra motor all aluminum or are the cylinders steel sleeved?
2003 Mustang GT
13.987@100.98 MPH
i beleve all aluminum
![]() 88 NOTCH,351 WINDSER,BUILT C6 TRANY,750 CFM CARB,4:30 GEAR=??? WWIII 2003 MUSTANG GT SOLD with 488 RWHP and 520 FT-LB on 150 shot and bolt ons R.I.P. |
That's a list of good tips.. Thanks..
I think it's all aluminum...
HID Lights |
82 Mustang Coupe w/a 429
I build perf atv and sled engines, they all are high rpm aluminum block engines, and they all have cast or steel sleeves. I would think that if the 4.6l aluminum block had bare aluminum cylinders you would end up getting a instant bore job by the much harder cast or molly rings!
Then Again, I Have Been Wrong Before, And Likely Could Be Wrong Again!!! ...I just had to check, I pulled out my Ford Racing catalog and am looking at the Aluminum 4.6l blocks, and the "Aluminator" blocks, and I can't see any sleeves, then again, the pics aren't all that good for detail. |
I just bought a 91 5.0 coupe, I went out to start it up today and im getting all power when I turn the key but nothing to the starter. No click, no sound, but the the fuel pump does cut on and all dash lights work. Any ideas? Thanks!
Never mind! Bad clutch switch. Thanks anyway.
Very helpful info. Thanks
Mustang HID Kits |
Thanks for this information, last week i face oil filter problem and i have spend $500.
If i had got this last week, i hope I would save my $500. -------------------------- Used Dodge Trucks for sale |
If your engine is making nominal power, would it warrant to still perform a leak-down test...?
I am getting knock below 3,500 RPM at 3/4 to full throttle for a brief instant; the time you smash the pedal and the engine responds and begins pulling. As soon as the engine begins to pull it no longer knocks. Its not a tuning or spark plug issue as these were already looked at. There is a tidbit of history though. I drove the car for 28,500 miles with standard GT plugs when it should of had HT0 (one step colder). So for 28.5K miles I drove it knocking... Roush I guess forgot to change out the plugs when they built my car... Would knocking for that long prematurely wear the engine out or cause some non-fatal mechanical failure? The engine currently makes excellent power. Thanks for any suggestions or help...
ROUSH Detroit Muscle | Refined 2008 Stage 3 Roush "VMP Tuned" ![]() Stock: 368HP/353TQ | VMP500 Tune: 432HP/414TQ VMP Dual Fan HX, FRPP TB, 12% OD: 447HP/440TQ
Ford Electric Supercharger |
Look Ma! My First Post!
Please help.
I Have A 1996 Mustang Gt Convertable 4.6l V8. I Have Been Trying To Figure Out This Missfire. I Have Replaced The Intake Manifold It Was Cracked. I Replaced Both The Coil Packs. Replaced All The Wires,plugs. I Replaced The Egr Sensor. I Replaced The Stock Manifolds One On Right Had Crack. Put New Lt Headers In With X Pipe And Flowmaster Mufflers. New Fuel Filter. NEW ALTERNATOR. I Checked All The Visable Vaccum Lines They Seem Fine. I Sprayed Brake Cleaner Around Them And The Plenium But Nothing. When Driving It Bucks When U Get On It And Pops At Idle Occasionally. When The Check Engine Light Comes On It Reads Cyclender # 1 Missfire. I Replaced Cyclender # 1 Fuel Injector Also. Could It Be Another Injector? The Car Only Has 64,000 Miles But It Did Sit In A Garage For A Long Time Unused. Thanks For Your Help
KB'd GT
I have some more technical stuff i can add to the general tips listed above.
Fuel Trims are off bank to bank - Trick Tuners Forums If you have a hanging or high idle - Trick Tuners Forums How to find a vacuum leak - Trick Tuners Forums How to clear the P1000 code for emissions testing - Trick Tuners Forums Misfire and spark blow out issues explained - Trick Tuners Forums Car stalls on clutch in - Trick Tuners Forums |
Recently I've been getting a few clouds of smoke coming out of my exhaust when I either start it up or rev it up a bit so I went to autozone and got a compression test kit and did a check on all 8 cyl's on my Cobra to see if I blew a head gasket or something. All cyl's were either 110-120psi except for cyl's 7 and 8. I checked 7 four times and got 80,85,95&100psi. I did 8 two times and got 85&80psi. Also every sparky plug end was pretty much either brown or black from oil when I took them out. The tip of the compression gauge had to be cleaned off after each cyl. was complete. The exhaust smells like terpentine too, got a little dizzy check that part of the equation lol. I don't know how long the plugs were in there b/c i'm the 3rd owner but the car has 70,125miles on it and I'm not do for a tune up anytime soon. I ran out of light and couldn't check the coolant lines for leaks but I doubt there are any leaks b/c i'd be able to smell the antifreeze burning but i'll check that tomorrow.
Do any of you guys have an idea what's going on with my engine? If it is a head gasket does anyone know where I can find a how too outline? Any help would be greatly appreciated!
Engine Mods: slp loudmouth catback exhaust, pacesetter h-pipe, k & n cold air intake, jet chip Body and Interior Mods: Saleen front bumber, 18" chrome saleen rims, GT rear bumper and drop zone 2" lowering springs |
Threads Similar to: Engine Problems? (LOOK HERE)
| Engine Problems? | James | 99-04 | 14 | March 2nd, 2011 02:20 AM |
| Help! (Engine Problems) | 97ponylover | Modular Mustangs | 13 | February 9th, 2009 11:13 PM |
| engine problems | bryant1205 | 5.0 Mustangs | 4 | January 13th, 2008 10:09 PM |
| engine problems? | B.A.M302 | 5.0 Mustangs | 5 | September 5th, 2007 12:49 AM |
| engine problems? | B.A.M302 | 5.0 Mustangs | 7 | June 5th, 2007 01:27 PM |
