MM's resident Juice head
07 Mustang GT
WOT micro or Window switch
hey guys...do I need both the wot micro switch and a window switch ....im getting the idea that a window switch does the same thing as a micro switch...and by reading some installs...guys are only using window switches on their s197.
![]() The MGW short throw shifter Its not just a shifter...It's a lifestyle! |
no....u can just runa window switch and will be fine...
i have the edelbrock window switch.... |
but you need a tach adapter when you run a window switch....msd and auto meter has them....
you need one cause you will not get the right rpm signal... |
07 Mustang GT
already got the adapter...Autometer
07 Mustang GT
what nitrous kit u runnin rebuilder?
edelbrock plate system (wet)....what shot you going to run..???
07 Mustang GT
50....get it tuned in ...then 75....same thing...then ill settle on the 100. anything above that isint recomended with the stocker fuel pump
Cigar Assassin
if you get the 8969 msd window switch, you won't need a tach adaptor.
i am running both window and wot switch. I don't want the juice spraying on accident if I am just cruising down the road in that window. better to be safe than sorry. |
2003 SVT Cobra
Get the WOT switch also. They are a lot cheaper than a motor rebuild. When you start cutting corners on nitrous than you are asking for trouble.
![]() 03 Cobra-Slow 02 SS, 00 Z/28-Gone Rest In Peace Travis Billings
Proud American
How is that the case? Dont the 99+ cars have to have a tach adapter for any tach related item?
07 Mustang GT
Okay thanks...the kit came with the WOT switch...its just I read an article where you cant hook them up to these drive by wire cars thats all.
#13 | |
07 Mustang GT
Threads Similar to: WOT micro or Window switch
| Window Switch | mystang0673 | General Tech | 3 | November 19th, 2007 06:58 PM |
| rpm window switch. | mustangrebuilder | Audio/Video | 0 | September 18th, 2007 09:58 PM |
| rpm window switch. | mustangrebuilder | 2005 - 2010 | 0 | September 18th, 2007 08:37 PM |
| window switch | barksdaleammo | General Tech | 31 | May 23rd, 2007 10:33 PM |
