Vortech Supercharger, Whats A Safe Pulley Size...
Old September 25th, 2006, 12:14 AM   #1
97TunedMustang's Avatar
97TunedMustang is on a distinguished road
Send a message via AIM to 97TunedMustang
Ive replaced the stock pulley awhile ago with a 2.87 I however think i might be able to go one step lower. I would like to go with a 2.62. According to vortech i believe i read somewhere, the max rpm for the blower internally is 50,000rpm and there is a utility to calculate where your at. Even if i was to shift at 4900 max which usually its lower since 4500-5000rpm is crap anyway with stock cam, its showing i hit 47,000rpm. Now granted generally im going to be shifting at more like 4600rpm that put its at 44,244rpm which seems fairly safe. Does anyone know how close i can get to the max rpm and be safe. I have no interest in blowing it up but if somone with more knowledge then i can tell me what would be safe itd be greatly appreciated.
95 Civic Ex, FnF1's, Morimoto Mini h1 retrofit,
GSR, bbk intake, BDL tb, 57trim t3/t4 8psi, 297whp
96 Civic Ex 2dr, G3 HID retrofit, FnF type 1's, Si cluster, Obd1 Z6 swap
Old September 25th, 2006, 10:05 AM   #2
mdvaldosta's Avatar
11.47@120.58
You've got a 2.87 pulley and your belts not slipping like crazy? You got an 8 rib kit? How much boost are you seeing? PS - 4600 rpm is way too low to shift, your loosing out on alot of power having to drop to like 2500 rpm between shifts. Even with the non-PI setup you'd be better off going to at least 5,500 rpm. Do you have a dyno sheet?
Old September 25th, 2006, 12:08 PM   #3
Drgnracin72's Avatar
i think he has a v6
RIP
ΜΟΛΩΝ ΛΑΒΕ
One Big Ass Mistake America
SHEEPDOGS
Old September 25th, 2006, 08:06 PM   #4
Yes it is a v6 and its not slipping, its a 6 rib. I hit max 6.5 lbs of boost driving. revving, it will go to 7lbs or maybe a little over. i dont have any dyno sheet. never been dynoed
Threads Similar to: Vortech Supercharger, Whats A Safe Pulley Size...
anyone know pulley size? BoostHard1210 99-04 0 February 24th, 2007 09:15 PM
vortech pulley change 2001bullitt 99-04 3 January 19th, 2007 12:09 AM
vortech pulley size? boost? belt ? faststang General Tech 20 August 26th, 2006 09:17 PM
