96 GT Running Lean on both Banks
I have taken my 96 4.6 to the dealer because the check engine light is on and they ran some diagnosticts and said it is running lean on both banks. I was told that I should change the DPFE sensor and the MAF sensor and that should Fix the problem. I have changed both sensor but the light is still on. does any one have any ideas or has any one else had this problem? It does have a K&N air system.
Idiot Lights
is it still running lean or is the light still on? Cuz sometimes those lights just go on for no reason. It also might be a short in the wiring. You aren't the idiot just the lights.
Did you have the code cleared after you changed the MAF?
The light came back on so there for I assume it is still running lean. I installed the new MAF and cleared the codes went for a little test drive and the light came back on.
what is your fues press set at?
Threads Similar to: 96 GT Running Lean on both Banks
| RUNNING LEAN !!!! | 97MUSCLESTANG | Modular Mustangs | 6 | March 5th, 2007 09:03 AM |
| Difference between running rich/lean | 1996gt | 96-98 | 3 | January 29th, 2007 03:30 PM |
| My Car Is Running Too Lean, How Do I Fix It? | SPEEDRACERCHICK02'92' | 99-04 | 10 | December 13th, 2006 11:54 PM |
| 1995 5.0 Running Lean | jcc1991 | 5.0 Mustangs | 3 | September 7th, 2006 10:58 AM |
| A Running Lean Code DUN DUN DUN!!!!!!! | 97Cobra | 96-98 | 4 | March 6th, 2006 11:06 PM |
