Overdrive
Old October 2nd, 2006, 05:16 PM   #1
The eaglenator is on a distinguished road
Overdrive
My 00 mustang has an overdrive button on th side of the shifter. Does it disengage it self when you slow down or stop? And when is the best time to engage it? Never seen an overdrive button like that before and I've had lots ofdifferent types of cars. First mustang and will always have one for now on. :stickit
Offical MM Zepplineers crew member #4-Commander
Old October 2nd, 2006, 05:21 PM   #2
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
its an extra gear...basically a 5th gear. best to use it on the high way so you dont waste as much gas
you'll notice when you start going about 60-70mph your rpms will be high, hit the over drive n it'll go down
[SIGPIC][/SIGPIC]
Acmillr loves me
Old October 2nd, 2006, 05:39 PM   #3
99mustang232's Avatar
1999 Ford Mustang V6
99mustang232 is on a distinguished road
the button is for actually for cutting overdrive off, hence the light that illuminates on the console when you press it "O/D OFF". the best times to cut overdrive off is when your towing, driving in the mountians or doing racing where you want to stay in 4th and push higher RPM's. Also cutting O/D off will promote more engine based braking, thus better for driving in the mountians. there are also various performance changes that can be had with aftermarket tuning changes to O/D OFF with companies such as SCT. Also O/D on and off is not automatic it only changes when you press the magic button.
...even fire and single cammin
1986 Ford F-150 5.0L 2WD
1994 Toyota Pickup 2.4L 4WD
1999 Ford Mustang 3.8L V6
2002 Jeep Grand Cherokee 4.0L 2WD
2008 GMC Sierra Denali 6.2L AWD
Old October 2nd, 2006, 07:38 PM   #4
I haven't notice any light on the console but I'll check it out.
Thank you both I went out and checked and you where right. I was watching the road and missed the light. I usually only check my gauges.Never trusted idiot lights.
Old October 14th, 2006, 02:30 PM   #5
I checked out the light and it was there. Getting my eyes checked next week Thanks after that it was pretty easy to figure out :sleep
Threads Similar to: Overdrive
Overdrive Question? 98GreenGT 96-98 12 October 4th, 2007 11:12 PM
98 GT Overdrive Noise tonyandtiger 96-98 2 September 2nd, 2007 09:09 PM
HOW MANY MUSTANGS OUT THERE WITH OVERDRIVE? bluebyu 5.0 Mustangs 2 August 29th, 2007 07:48 PM
Anyone know how to use Overdrive for MPG?? Kenzo V6 Mustangs 17 August 29th, 2007 04:11 PM
overdrive vichael1 99-04 33 January 17th, 2007 11:57 AM
