Tubular K Member Install
hey guys would anyone know how long it will take to install a k member on my car so i can free up space i need to install my turbo piping on my 96 mustang gt???what will i have to change along with it??and will i have to pull the motor??
11.47@120.58
No you won't have to pull the motor. It'd be a good time to get tubular a-arms though... and you'll probably need an alignment afterwards. Make sure you get spring perches unless your going to be running coilovers. It'll probably take a half day or so to swap.
ohhok good then..so i might just get some new coil overs and a arms then where would be the best place to get this stuff by the way??any solutions??
Make sure you have an engine hoist to hold the engine up.
yeah we own a trans shop i just never done anything like this you know..my dads done just about everything though he will probably help me to..
RLY SRS
Let us know how it goes and if it is a big improvement over stock...
I am thinking about doing the same... |
#7 | |
RLY SRS
I guess I should invest in one as well then...Its a good thing I am amking decent money over here in the desert...
11.21@123 -150 shot
![]() iTrader: 1 reviews
Helped a buddy install a tubular AJE k. He went with Fox A arms. Either the jib moved or it spread a bit when it was cooked for the powder coating. We had to fab spacers some small spacers. It is a nice looking setup. Lots of access now and saved some weight on the front end. I am considering it now for my Mach. :wink
im gonna do it to mine also, when i go turbo becasue i have to but have heard it can save as much as 45 lbs but they also make some noise
yeah you to drgnracin72 i have to for my turbo also...and they can save up to 65 actually im trying to find a red one now....
#12 | |
AJE K-members have compressable bushings built in. It looks at first like the control arms are too loose but once you tighten the bolts the bushings compress and take up the slack. I thought the same thing you did the first time I picked up an AJE k-member.
#13 | |
11.21@123 -150 shot
k member
It can be done without the motor in but it is a pain. I did mine before the motor was in and with the car on a lift it is easier to remove the old member cuz you can lower it with a tranny jack. the new one is so light you can hole it in place while someone bolts it on. If you have to do it with the motor in make sure you have the car on jackstands as high as you can go and still beable to jack the motor. like I said the hard part about havin the motor in is gettin the old one out....Good luck!!!
11.21@123 -150 shot
We rigged up a sling and suspended the engine from above. Dropped the ps rack and stock k. Put the tubular k back in and replaced everything. It was a pretty straightforward install. I am seeing one in my future.
how long did it take you??
11.21@123 -150 shot
It probably should take no more than 4-5 hours but we were screwing around with other things. Fixed a leaky connection on my line lock. Changed the tranny and rear oil. Drank a few cold ones. We started on a Saturday afternoon and finished it up the following Sunday afternoon. Our mod sessions seem to end up as a social gathering. Many times other buddies will stop by and BS and it always ends up taking more time that it should.
haha yeah but thats the best man just working on your own stuff with friends...and really thats about the best thing ever...beer and cars...right
1999 Ford Mustang V6
when you guys choose to buy one let me know, maybe we can find someone to do a group buy because i want to get the AJE k-member #MU-4000 94-02 K-Member, (mild steel no motor mounts) and our two authorized vendors don't deal in AJE parts, but JEGS does
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
#20 | |
11.21@123 -150 shot
Threads Similar to: Tubular K Member Install
| GMS Mustang Tubular K member Kit w/ A-arms, K member, & | 94GTD1SC | Drag | 1 | November 16th, 2007 01:11 AM |
| Tubular K-member kit | acmillr | 99-04 | 28 | August 21st, 2007 02:06 PM |
| Is a Tubular k member a must? | caintcatchmyGT | General Tech | 9 | August 3rd, 2007 12:29 PM |
| k member install | droppedbass87 | General Tech | 4 | December 25th, 2006 06:49 PM |
| Tubular K Members | 90ProjectStang | 5.0 Mustangs | 2 | August 24th, 2006 07:10 PM |
