E Brake Handle Loose...
is there anyway to tighten the slack on the handle at all, it lifts up about 1/2inch before engaging
2000 V6 Performance Red @ Cardomain Was fun but a waste... 1987 LX Hatch | Soon to be a 600hp monster |
im having the same problem..actually mines broken. but my dad and me are gonna fix it and do the brakes on my car and tighten the ebrake so it grabs better...next week tho...i can tell you then...
i think i fucked it up because sometimes i'd drive with it on at about 45mph and not notice
I'm preety sure the ebrakes are self adjustable.
they are, i just dont know how to do it yet
you sure your back brakes arent gone? could affect it some potentially.
![]() 95 Civic Ex, FnF1's, Morimoto Mini h1 retrofit, GSR, bbk intake, BDL tb, 57trim t3/t4 8psi, 297whp 96 Civic Ex 2dr, G3 HID retrofit, FnF type 1's, Si cluster, Obd1 Z6 swap |
turns out since im selling my car im not adjusting my ebrake..i think...idk if i do i'll be sure to post it
Chilton repair manual
ugh, i just got mine fixed, nip it in the butt now, the metal around the bolts is super super thin, and when i pulled up on my ebrake the bolt ripped right out of the metal and left a hole there, I had to make a plate, with a bolt welded on it and stick it there for a temporary fix, but then I welded another metal plate there, fed the bolt through and now it is fixed for good, alot tighter. Might be worth the time making sure its not that thin metal starting to bend...
Threads Similar to: E Brake Handle Loose...
| Loose steering | Veeder | 99-04 | 0 | July 24th, 2007 10:31 AM |
| E-brake handle assembly question | Nemesis | General Tech | 1 | June 12th, 2007 11:51 PM |
| Gas pedal loose | new 5.0 | 94-95 | 3 | January 24th, 2007 12:48 PM |
| breaking loose bad going into second. | GreenFaleen | V6 Mustangs | 19 | December 29th, 2006 12:23 AM |
| loose steering | theodoor24 | Classic Mustangs | 4 | October 19th, 2006 11:53 PM |
