nitrous backfire
Old October 18th, 2006, 07:12 PM   #1
Look Ma! My First Post!
jetmech is on a distinguished road
nitrous backfire
Hi all,
I just installed a Nitrousworks adj kit on my 93LX. I've been increasing the hp level a little at a time with no problems until now. I'm up to the 150hp jets and now when I get off the throttle it will backfire pretty good. Under load its fine. The plugs look good although I havnt done a proper check by clicking it off at the end of a run. I have a WOT switch as well as an RPM switch. This is my first time playing with this stuff so I figured I'd start asking questions before I have a rod thru the hood. I'm really just looking for general info on how to tune this system and where to start. Thanks
Old October 18th, 2006, 07:57 PM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
That is a common problem with wet kits on EFI cars. The EFI intake is designed to flow air and not fuel. Alot of people destroy throttle bodies with those wet kits that have the plate between the throttle body and intake. My suggestion would be to get a dry kit or an NOS plate kit that goes between the upper and lower intake.
Threads Similar to: nitrous backfire
Sluggish 94 w/backfire Flomaster_Knockoff 94-95 6 November 1st, 2007 08:46 AM
Backfire trace & fix cobradawg 5.0 Mustangs 8 September 14th, 2007 01:35 PM
88 Gt Convertible Backfire ridebmxfbm 5.0 Mustangs 22 June 11th, 2007 12:56 PM
nitrous backfire? N02coupe 94-95 2 April 2nd, 2007 05:11 PM
backfire ttop5.0 5.0 Mustangs 7 May 17th, 2006 10:25 PM
