IRS on a 96 GT
LinkBack (1) Thread Tools
Old April 20th, 2008, 07:59 PM   1 links from elsewhere to this Post. Click to view. #1
Genibus Nitito Canus
HBK_2007's Avatar
2009 Ford Mustang GT
next year
HBK_2007 will become famous soon enough
Send a message via MSN to HBK_2007
IRS on a 96 GT
How hard it is and what is needed (other than eBay Motors: 2003 2004 FORD MUSTANG SVT COBRA IRS REAR AXLE (item 280209986169 end time Mar-25-08 14:54:49 PDT)) to put the IRS off of a 99-04 cobra (yes i know they didnt make a 00 cobra) onto a 96 GT? has anyone on here done it? Ive read about the IRS and ive decided I want to run that on my car. If you think the solid axle is better, then dont waste the space in trying to change my mind cuz your not going to. another question, whats the difference between the cobra IRS and the thunderbird IRS?
Old April 20th, 2008, 09:21 PM   #2
coffinator6's Avatar
03 GT, 92 coupe 2.3T
coffinator6 will become famous soon enough
i dont know the difference between the cobra and t-bird irs but to install an IRS in a sn95 is drilling 4 holes for front mount i believe. I know its only 4 holes though. im just not sure if its the front or rear. i believe its the front because it uses the stock rear quat shock mount.
we have a guy here in OKC that has a 99 cobra IRS for $400. i dont know the difference between the 99 and 03 but I think it will work.
Old April 20th, 2008, 09:29 PM   #3
HBK_2007's Avatar
next year
the major difference ive seen is in the mustangs is 28 (99) vs 31 (03) spline and the 03 half shafts are a little stronger but i plan on upgrading the half shafts anyway. the reason im curious about the tbird is i can get a whole car for like $200 and just put the irs on my car and sell the rest
Old April 22nd, 2008, 01:45 AM   #4
HBK_2007's Avatar
next year
bump
Old April 22nd, 2008, 01:53 AM   #5
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
I wouldn't mess with the t-bird IRS, totally different chassis (MN12 versus SN95).
What I've heard is that the Cobra IRS was specifically designed to bolt up in place of the live axle. No cutting/welding/drilling/anything.
But, I've never done it, so take that as you will.
I'm also interested in swapping in IRS into my '98, but then I'd have to rebuy rear bilsteins, and I can't really afford the extra $300 on top of the IRS assembly and the 4.10s I'd be putting in there at the same time.
I'm also not sure if you have to change the length of your driveshaft, or what you have to do brakewise.
O o
/¯/______________________
\_\
Buy my Bronco, special deal for MM folks
Old April 22nd, 2008, 02:02 AM   #6
HBK_2007's Avatar
next year
ok. well like i said i can get a whole tbird way cheap so i might take a tape with me and check it out. if a different length drive shaft is needed, that would give me a good excuse to buy a Al DS. i think the stock brakes off the irs will work just fine
Old May 12th, 2008, 01:46 AM   #7
spdfrek is on a distinguished road
I've got a cobra irs under my 95 v6. Other then the four holes to drill in the frame its pretty simple I thought. Still have to make a brake line since I don't have abs. You can't just bolt the stock drive shaft up. I think you can pull the flange off you 8.8 solid and bolt it onto the irs instead and use it though. my motor and tranny are not stock, nor in stock location so the drive shaft will be custom built instead.
Old May 12th, 2008, 01:48 AM   #8
Smelly Fists, Socking Cocks
G.T. Rags's Avatar
Millenium Falcon
G.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant future
u'll need to get a dif exhuast as well
I would eat the peanuts out of her shit
Car Salesman Club - The Hammer
ModdedMustangs Conspiracy Group: President
Old May 12th, 2008, 02:09 AM   #9
HBK_2007's Avatar
next year
oh ya, i totally spaced the exhaust differences
Red 1996 GT: JLT RAI, Steeda Underdrive pullies, Stewart Waterpump; nothing to brag about
Black 2009 45th aniverary edition GT 5 speed: K&N CAI, BBK Twin 62mm Throttle Body, BBK Underdrive Pullies, muffler delete
Old June 17th, 2008, 03:12 AM   #10
'89 Mustang
erock420 is on a distinguished road
Would that swap work in an 89 Stang? I was just standing under a t-bird today thinking the exact same thing.
Old June 17th, 2008, 03:21 AM   #11
HBK_2007's Avatar
next year
well i just bought a Cobra IRS so it doesnt matter. I think tho if u want IRS, cobra is gonna be the way to go, i think the tbirds, actually i know, they have a wider stance and the frame rails might be wider too.
Old June 17th, 2008, 11:08 AM   #12
im putting one in my 89 with a svo motor. whould be a fun combination. 50/50 weight distribution.
the only problem you will have is the rear bolt hole where the old quad shock mound is, is about 0.5" to low. if you dont want to drill a new hole in your frame here is how to fix it. Removing that piece of steel where the bolt holes are and welding in a bigger one. then simpley redrill your hole. a better idea would be to make the a hold a .25" wide x 1" tall slot so you can bolt it up to any fox or newer mustang just in case you decide to sell.
Old June 17th, 2008, 11:08 AM   #13
how much did you pay? i paid $500 for mine
Old June 17th, 2008, 01:04 PM   #14
HBK_2007's Avatar
next year
400 but havent paid for shiping yet
Old June 17th, 2008, 05:56 PM   #15
Blainestang's Avatar
Blainestang is on a distinguished road
Seriously, I'm doing the same thing w/ my '93 Coupe, and as soon as I decided to do it, it seems like everyone is doing it.
By everyone I mean, 2-3 people, but I'd never heard of an IRS/2.3T Fox previously, and now I've heard of a couple other people doing that and several more going IRS on non-2.3 Foxes.
1993 2.3L Coupe [Motortopia] : Open-Track Project... 216k miles
2000 V6 (Black,5-speed) [Motortopia] : Heads/Cam (EXHAUST CLIP)
2001 Harley Davidson F-150
Acts 16:31
Old June 17th, 2008, 08:01 PM   #16
HBK_2007's Avatar
next year
thats cuz IRS rides awesome
Old June 17th, 2008, 08:13 PM   #17
And more importantly... HANDLES awesome (with the right upgrades)
Acts 16:31
Old June 17th, 2008, 08:40 PM   #18
HBK_2007's Avatar
next year
well im mostly in it for the ride
Old June 17th, 2008, 08:55 PM   #19
Different strokes for different folks...
Fortunately, the IRS is good at both
Acts 16:31
Old June 17th, 2008, 09:00 PM   #20
HBK_2007's Avatar
next year
yes
LinkBack to this Thread: http://www.moddedmustangs.com/forums/general-tech/67158-irs-96-gt.html
IRS News » Blog Archive » IRS on a 96 GT This thread Pingback April 20th, 2008 09:50 PM
