Discussing sub question in the General Tech Forum. Has anyone tried mounting a sub in their spare tire compartment. I would liek to ...
Old April 20th, 2008, 11:18 PM   #1
scxc15's Avatar
2003 Mustang V6
15.96@87.08
sub question
Has anyone tried mounting a sub in their spare tire compartment. I would liek to mount 1 12" sub in there but I dont know how it would sound. I know it would have to raise up quite a bit but I feel like it would save more space and be one less ting to slide around in the trunk....
Old April 21st, 2008, 11:27 AM   #2
03z28eaTer's Avatar
2003 Mustang GT
i dont know anyone that has done this to a mustang, but i was going to do it to my 96 eclipse, the tirewell should be the same, i found a writeup how to do it for a 95-99 eclipse somewhere, if i can find it ill send it to you, hopefully it will help.
03 DSG GT 5 Speed
18" DD Black Bullet's
3.73' Gears
Steeda UDP's - K&N CAI -
Accufab 75mm TB/Plenum
SCT Dyno Tune
Shaker Hood
Saleen s281 Spoiler
Shelby C-Pillar Scoops
Mach 1 Chin/Grill/Honeycomb/Louver
And Much More
Old April 28th, 2008, 10:00 PM   #3
Silver '07 GT 5spd
Did things like that when I managed a car stereo shop, install manager/head tech. You will need to beef up the sheet metal around it with something like Dynamat ultra/premium, the foil-backed one. I say that one because it installs the easiest, no heating required like with the standard one. Don't be afraid to use more than one layer either, the more you put one the better the damping effect will be. You DONT want to sound like some ghetto beater with 15's in the trunk rattling for 2 blocks, it ain't cool. Also Dynamat the decklid and walls of the trunk, because you are directly vibrating the sheetmetal, more so than if you simply put a speaker box in a trunk. No vibration = cool points. To raise the height you can cut rings of MDF and wood glue and screw them together. To seal them to the trunk bottom around the well you can start with expanding foam, trim the excess away, and then lay in fiberglass mixed kinda hot (you don't want it running all down inside). The outside finish is up to you, but is it was me I'd smooth out the rings you raised off the floor, build them into another false floor/cover, fill in the gaps with body filler, sand and smooth, then cover in vinyl. I always liked dark grey/charcoal colors and black for trunks.
If you want to put a little more time into it, then make your top ring out of 3/4" plexiglass and fit the woofer into the center. Remember to predrill your holes and nut and bolt it in, not screw as it will probably crack. If you hide the edges then you won't need to polish them out. Finish out the inside of the enclosure smooth and paint a lighter color. If your finish work doesn't come out too good, then look for some Duplicolor FlekStone ( I believe it's spelled like that, find it in the spray paint aisle at Home Depot/Lowes) and give it a light coat to hide the flaws. Mount some LED's or neon tubes on the underside of the top piece where they can't be seen and run the wires out with your speaker wire.
FI FTMFW!!! 445rwhp, 426rwtq
If you're in a fair fight, your tactics suck.
Old June 6th, 2008, 10:53 PM   #4
~C~
Y2K YellowJacket GT
~TBD~
WOW! Nice write up! That about sums it up!
I have a custom box with 2 10" and a 1400 watt amp in my vert. it fits right in the back of the trunk, so I still have some room in the front and around the sides. It really isnt bad but then again, I dont fill my trunk up with stuff anyway. I guess it depends on if you really want trunk space or not. A pair of tens in a custom box isnt that bad. If I can manage to get some pics of it, I will post them up for you if you want to see.
Blower in the garage....Install in T-4 days.
MILITARY CREW
LT
"Like the blind man says......We shall see...."
Threads Similar to: sub question
88' GT Speedo' Question. Plus Another Gauge Question. Mr_Evil 5.0 Mustangs 8 March 16th, 2008 01:31 PM
Exhaust question + supercharger (warranty) question r00st 2005+ 2 January 31st, 2008 11:07 AM
Muffler question (visual aspect) + Emblem question warrior86 Visual 6 November 20th, 2007 09:55 PM
