Discussing I need some help please, I've been having some troubles... in the General Tech Forum. Hello, my names Tyler.. I've been having a few troubles with my 99 Gt. ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1999 Mustang GT
N/A
I need some help please, I've been having some troubles...Basically, I took my car to a shop of a friend... He didn't have my particular fuel filter and installed a different one... However that isn't the worst f my problems... I originally changed it because Ever now and again it would run a little rough, just barely though. Previously I had a bad idle, which was corrected after tuning the throttle body a little. Also the car would SOMETIMES die when I put it in neutral and was slowing from speeds above 50. ( Usually don't use neutral though. ) Some time after changing the filter All my problems got worse... One day my car was running like crap and I lost all power.. Basically it died and when I restarted it things were running smooth again.. A few days later the problem started again. A few days after that it got so bad the car wouldn't run anymore. At this point in time I didn't have the funds to work on it... At any rate I went to the dealer and bought it a NEW IAC Valve yesterday the 20th. And after installing it I reset the computer. Took 2 tries and it started up. I had a friend ride with me to the gas station... Along the way it died on me again but started right back up. I noticed that when I would get on it it would have Problems. ( I am assuming due to fuel filter. ) I purchased a new fuel filter but have yet to install it. I had wiggled the old fuel filter and started it up... It drove great for a while, no problems at all... This morning I went out and started it up! It was running like a champ.. Again more troubles! 3 miles down the road my check engine light came on... I quickly pulled into schucks and used the obd 2 scan tool they had... At which time it told me " Running Rich in Bank 1 ." Which to me means Bad oxygen sensor or Leaky Fuel injector... However I was curious if the fuel filter would have something to do with that as well.... Please help me figure it out... I don't have a ton of money to try and fix Every tiny thing in assumption that it'll be the problem... Any advice or other would be very helpful!! |
1989 Mustang LX
10.98@126.7 NA
Had the same problem and it ended up being the mass air sensor
Never fast enough.
2007 MUSTANG GT
I dont know but it doesnt sound like the fuel filter is the problem
![]() Originally Posted by ChrisJ If the erection last over 4 hours...Call more women... |
2007 MUSTANG GT
If it was me I would seafoam it!!
1999 Mustang GT
N/A
Oh
Mass air flow hu... Okay well I am going to wait an hear a few more responses, thank you though !!
Threads Similar to: I need some help please, I've been having some troubles...
| having some troubles | Blk01ponyGT | 99-04 | 4 | February 14th, 2008 08:04 AM |
| VT Troubles | limited | 99-04 | 33 | November 21st, 2007 07:39 PM |
| Livewire Troubles | Modern_Muscle | 2005+ | 4 | November 17th, 2007 02:35 AM |
| TKO 600 troubles | 88lxmustang123 | The Clubhouse | 0 | January 5th, 2007 12:42 AM |
| 94 Mustang Oil Pan Troubles... Buy New One? | redlinetoys | 5.0 Mustangs | 14 | October 10th, 2006 08:55 AM |
