Stroking, Boring, Blueprinting, etc.
Old October 27th, 2006, 09:54 PM   #1
MSO
MSO is a jewel in the roughMSO is a jewel in the roughMSO is a jewel in the roughMSO is a jewel in the rough
Send a message via AIM to MSO
i know this may seem like a stupid question to some of you, but I'm illiterate to engines. so my question is this: What can you do to an engine to make it more powerful, like boring and stroking or w/e, or blueprinting it, or getting new computer chips?
maybe u can refer me to a book or website that can clear these things up?
i've been googling that all day but i guess i can't find the right words to search for..
i sound like such a newb, AND DONT SPAM MY POST CHRIS (nah j/k :wink )
[SIGPIC][/SIGPIC]
Old October 27th, 2006, 11:35 PM   #2
Screemin3o2 is on a distinguished road
Send a message via AIM to Screemin3o2
are you really asking or did you just make this post to take up space? just asking because of the nah j/k at the end.
95 Mustang GT
Slow Bolt On Car
www.steelcitystangs.com
Old October 28th, 2006, 12:33 AM   #3
MSO
im really asking.. u got me all happy i thought some1 had answered me.
and it gets spammed anyways.. *sigh*
[SIGPIC][/SIGPIC]
Old October 28th, 2006, 12:57 AM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
This subject could go on for years..........
Short answer, find a good engine builder.
Old October 28th, 2006, 06:47 PM   #5
MSO
i dont plan on doin it anytime soon i jus wanna kno so in case i ever hav a lil extra cash i cud kno if it is a good idea
[SIGPIC][/SIGPIC]
Old October 29th, 2006, 11:45 AM   #6
stang fanatic's Avatar
stang fanatic is on a distinguished road
boring and stroking can create more power, so long as the remaining components are installed to work with the setup. Blueprinting is just that...making a blueprint of the engine you build...time consuming and not a power adder at all....as for the rest, if its efi, computer reprogramming or fuel management systems add ons are needed for seriously larger output setups.
"The gods too are fond of a joke."
"If I had only known, I would have been a locksmith. "
Old October 29th, 2006, 01:27 PM   #7
I wasn't spamming, I was asking if you were seriously asking the question since there are people that make posts on here just for attention. I wasn't making the post to be an ass.
Any type of boring and stroking will always give some sort of change in your hp/tq curve as long as you have the induction and fuel system to provide it with what it needs to breathe well. Boring the block means to more or less cut away material inside of your cylinders to the extent of making more displacement without hurting the cylinder walls. Stroking is just adding more length to the stroke of your engine which also gives more displacement. Blueprinting just means to basically build your engine to the specs and clearances that you have set out for it and checking and make sure they are right. That's a basic overview of those terms, I can go in more depth if you like.
Engines run off of an air/fuel mixture. The more air and fuel you can put into an engine while doing it safely and keeping the ratio where you want it, the more the engine is going to love it. An engine also will provide as much power as it can for your which is why you want to make it easy on the engine. There are tons of things that you can do for this like taking out your a/c system, even windage trays or going as far as putting a knife edge on the counterweights of your crankshaft, it all goes on and on.
Anymore questions, let me know.
95 Mustang GT
Slow Bolt On Car
Old October 29th, 2006, 09:51 PM   #8
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Some things a good engine builder will do:
measure ring end gaps for each ring and file each ring accordingly so all gaps are the same, fit each bore to each piston and number pistons accordingly, check all bearing clearances and adjust where necessary, debur block for better oil flow and drain back, possibly modify oil passages and/or install oil restrictors, adjust piston height in block for proper quench volume, etc. Those are just a few things and everything either makes more power or makes the engine more reliable.
Old November 28th, 2006, 12:39 PM   #9
MSO
ok how about a 351W. lets say u wanna get 400hp (just a random figure), how could you get that (from the engine, not talkin bout exhaust etc.) w/o power adders?
i kno there are different combos so jus gimme wut u think wud work
i plan on saving one from a junkyard sometime in the near future (gonna be a bitch converting from a 2.3L)
[SIGPIC][/SIGPIC]
Old November 29th, 2006, 05:32 PM   #10
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
400hp from a 302 is easy......from a 351 is easier.
Old November 30th, 2006, 04:32 PM   #11
MSO
how so? do tell..
[SIGPIC][/SIGPIC]
Old December 1st, 2006, 05:47 PM   #12
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
how so? do tell..
Do research or find a good engine builder. I have posted information regarding this several times. I'm not going to keep reposting the same information everytime someone asks. 400hp is not rocket science, not even close.
Old December 7th, 2006, 12:38 AM   #13
Cskit1500 is on a distinguished road
and converting from a 2.3 to a 351w isnt hard either, In the process right now 2.3 aod to 351w with c4.
Just purchased:
351w 70k miles/needs carb ($300)
8.8 rear with 31 spline and 4.11 gear ($300)
only thing left to buy - motor mounts and tranny/bell housing. Have it and a carb lined up just w8ing on final price.
Old January 5th, 2007, 01:36 PM   #14
Severo Diaz is on a distinguished road
I can help u (CHP) probe indusries has a very good engine program, I got a 347 from them runs very good!! it runs mid 12's all motor with stock ported E7 heads, I think that is good for a daily driven mustang, I work at probe indusries so hit me up I will help (Severo Diaz in sales).
Old January 7th, 2007, 03:53 PM   #15
rodenberg's Avatar
rodenberg is on a distinguished road
these are things any engine builder who is getting paid should do!
bracket racing sucks
Threads Similar to: Stroking, Boring, Blueprinting, etc.
Stroking a 306 Tony_90fox 5.0 Mustangs 48 March 20th, 2011 12:00 PM
blueprinting chevy_killer 5.0 Mustangs 3 November 22nd, 2007 03:46 AM
stroking the 2.3 MSO 2.3 Mustangs 30 October 24th, 2007 10:29 PM
Stroking my 6er Juggalo_X V6 Mustangs 21 September 20th, 2007 03:00 PM
Stroking a 351w Spiderz Classic Mustangs 1 August 15th, 2007 12:21 PM
