DIY foxbody twin turbo build
87 5.0, GT40 Irons, Performer Intake, AOD
Turbos: Garret T3 "50" trim .42/.48 A/R Pics found here: http://whiteyhimself.shackspace.com/john/ Wiring moved into fender cleans it up real nice passenger side mount. passenger side mounted working on drivers side drivers side done drivers side mounted hello turbo ![]() passenger mounted drivers side downpipe, gotta get some vbands to attach it to the h-pipe passenger side downpipe done what intercooler? i got gas!!!! mmnnn some purrrty welds
'96 Exploder XLT 5.0 AWD "turbos coming soon" |
WOW Thats going to be faster than NOS?
#3 | |
#4 | ||
#5 | |||
When you gonna come over and tap my.....pan......
cap one side and put air in there and put the pipe under water. Maybe a fitting for the air hose.
#7 | |
Re: DIY foxbody twin turbo build
little update :wink
1999 Ford Mustang V6
what did you spray your pipes with?
iits high temp "header" paint from advanced auto, in aluminum color.
anybody thing the power steering line would have a problem being like that, im gonna zip tie it in place, Im trying to keep it off the downpipe, i dont think it would like that too much :wink
icantdo55 is coming over tomorrow to help tap the pan. if all goes well it will be running soon.
#14 | |
I am assuming that you are wraping/sleeving your plug wires too?
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
you mean there not already heat protected? dam lol, yea i gotta get some of the sleeving stuff, really only 2 plugs need it and the coil wire, its gonna lay right on the header haha. still need some air filters too
looking good. when ya gonna fire it off?
hopefully soon, few more parts to put on and a few things to tiddy up, then soon after it will be comin to you for a transmission
Hey got a mod for you on pressure testing your whole system. I use it on mine. go to home depot and get some pcv piping one strip about a foot or so long and cut in half cap one end off with pcv cal and cap the other one too. on one of the ends drill and screw in a air compressor adapter. Then clamp in at each end of the system(ex. from where pipe starts from intake to all the way back to the rear). Great way to test clamps soapm up and also listen for hisses with no car running its a breeze. With my STS was great at finding leaks in the exhaust. Warning tho pressurize slowly with air compressor. If you need help let me know. Ill be around this weekend and can show you how to make one. Cant wait to see your beast run. I need to talk to you also Twist about a good build on a t5
92 Ford GT- I guess its stock and just loud. 98 Fireturd- I guess its stock too. Just a little bit more louder and whiner. |
i found some rubber pvc end caps that i used. and just jb welded a valve stem into the end of one. was able to test to 16psi before the cap blew off lol.
#20 | |
Threads Similar to: DIY foxbody twin turbo build
| Turbo HorsePower Twin Turbo kit | dblindberg | 2005 - 2010 | 34 | June 17th, 2007 08:05 PM |
| Supercharger, Twin Turbo, and Single Turbo | justinsstang | General Tech | 24 | March 7th, 2007 09:07 PM |
| Mellon's Twin Turbo Stealth vs Wills99z's Single Turbo z28 | Mellon | Videos | 10 | December 30th, 2006 10:05 AM |
| Turbo, Twin Turbo, Procharger, or Kennebell? | black94gt | 5.0 Mustangs | 19 | October 7th, 2006 10:41 AM |
| Super Charger vs Turbo/Twin Turbo: Pros and Cons of each | FireryDriver | 2005 - 2010 | 9 | September 17th, 2006 04:15 PM |
