Odd Sounds When Making Tight Turns
Hey guys,
I've noticed a strange binding sound when I take tight turns in my 04 Mustang GT. It's like a deep clicking sound, and sometimes it happens under hard acceleration also. It is a fast series of clicks, almost a knocking sound. A friend said to me that he thought it might be my bushings, but the car only has 15K on it and has been taken care of well. I had a 99 GT before and never noticed this. Thanks for any advice you guys can offer. |
11.21@123 -150 shot
![]() iTrader: 1 reviews
Welcome to MM. Is it a stock rear end? An aftermarket locker differential can make clicking sounds when making a sharp turn. Give us some more info and try to isolate the sound if you can. Post up some pics of your ride.
Thanks for the reply!
The sound is coming from the front end, and I can vaguely feel it through the floorboard. The rearend is stock. I do have a Steeda anti-sway bar that I will be installing soon, and I think that came with new bushings....if I remember correctly. |
what about new rims and tires? did you install any type of aftermarket rims? because i put some cobra r's on my 98 GT, BUUUT i dind't tighten the lug nuts tight enuff, and it was making a sound, the lug nuts were pretty loose. and making a clicking noise, so if you have after market rims, check your lugs!
1998 Mustang GT Super Charged! CGS Sub frames, Auto Meter gauges, Bassani Exhaust! |
not sure about your car but when I had 9 inch wheels up front, the would rub the inner fender. I don't think any of your steering components would go that bad with only 15kmiles on them.
Also have groaning sounds when making corner turns both left n right coming from back wheels, was told bearings?
i have this same problem coming from the front... i have no idea what it is! it's not consistant at first i thought it was tranny or driveshaft related but then that doesnt make sense.. i can avoid it when i give it a little gas and slip clutch it while turning... anyone ever had this problem?
1999 Ford Mustang V6
balljoints?
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
sounds like ball joints.... mine did that when they went bad...
also one time when i brok a motor mount it made a similar sound under accell.
http://www.cardomain.com/ride/2461223 1994 GT: MSD 6AL, BBK O/R H-Pipe, Dynomax Race Bullet mufflers, 3:73 rear, Hurst Short Shifter, MAC cold air intake & much more coming soon! |
mine does the same thing now when i roll it sounds like a clunk clunk clunk sound by the frond driverside wheel and i can feel it in the floor boards
#11 | |
Threads Similar to: Odd Sounds When Making Tight Turns
| the starter still turns after I let off the key!! HELP???? | topgun_96 | 5.0 Mustangs | 23 | July 10th, 2007 09:56 PM |
| car turns off | hmotes | 5.0 Mustangs | 8 | June 12th, 2007 07:09 PM |
| tight shifter | cobraetti | 99-04 | 8 | May 30th, 2007 04:18 PM |
| Tight Tight Pulley | guesswatidrive | General Tech | 2 | April 17th, 2007 09:22 PM |
| Need stronger bottom end, tight budget, but want it right | coolridgedug | 99-04 | 8 | May 29th, 2006 03:07 PM |
