powerdyne help
Old November 15th, 2005, 09:51 AM   #1
timmy40 is on a distinguished road
powerdyne help
These instructions are awful. Were the hec dose the bypass valve for the smog pump go???? Every thing else is done, (pretty easy) but I can't figure out exactly how this thing needs to be hooked up. Help anyone.
Thanks,
Tim
Old December 21st, 2006, 03:32 PM   #2
blownsnake is on a distinguished road
The bypass valve is not for the smog pump. it goes between the boost tube and the air intake tube. when you let off the throttle at boost the blower is still turning and making boost so it gives it somewhere to go (back to the blower intake) instead of ramming the air into a closed throttle body. Hope that helps.
By the way, you are indeed correct, those are the worst instructions Ihave ever seen and powerdyne customer service is just as bad. Good luck. One other thing get it dyno tuned the chip they give you is junk and most likely not even for your car. I went through 3 of them they sent me before I gave up and got it dynoed.
Current and past rides
2003 Cobra
2003 Saleen
1993 Cobra
1984 Capri (yes it was a 5.0...)
1991 Mustang Coupe
1977 Cobra ( first car)
Threads Similar to: powerdyne help
powerdyne superchargers? B0B 99-04 6 June 6th, 2007 11:14 AM
powerdyne supercharger 2004GT General Tech 7 June 4th, 2007 07:18 PM
powerdyne Monster stang 97 96-98 20 May 10th, 2007 02:37 PM
Powerdyne is in my garage! badtzmaru 5.0 Mustangs 11 August 2nd, 2006 03:53 AM
