Discussing How to Write up Comming! in the General Tech Forum. Ok since you chumps were so usefull in my last thread (/end sarcasm). I decided ...
Old May 28th, 2008, 10:18 AM   #1
'02SilverBullet's Avatar
Ok since you chumps were so usefull in my last thread (/end sarcasm). I decided Im gonna go ahead and do a write up on this AC work im planning in a couple hours. Hopefully we can all learn a bit from it!
Mods Include......
BBK CAI
MM Caster Camber Plates
Baer Decalla Drilled and Sloted Rotors
w/ painted callipers
Hypercoated 18x9 FR500 Rims
Eibach Pro Kit Lowering Springs
More to come.....!
Old May 28th, 2008, 01:04 PM   #2
94v6blkndred's Avatar
1994 Mustang v6
slower than your average snail
hey i tried to help!
http://www.moddedmustangs.com/forums/signaturepics/sigpic6856_1.gif
XBOX TAG- DioMurksAll
1994 V6. red interior, black w/red side/hood scoops and taillights.CAI,Custom X pipe w/FORCE mufflers, 3:73's
Old June 1st, 2008, 09:53 PM   #3
travis_afx's Avatar
'02 GT
Hey when ever i changed a/c componets i added the oil through the machine when i was recharging the refrigerant(sp?) But sorry i cant give you an exact number of how much oil its gonna take. Just tell the shop thats going to evacuate and recharge the system to add the oil also.
And make sure you wet all your new o-rings with the comressor oil before you install the lines, DO NOT put the o-rings in dry.
BBK CAI, 75mm BBK TB, Trick Flow plenum, U/DP, spec clutch, short throw shifter, adj. upper cntrl arms, lower cntrl arms, 50/50 shocks, MAC exhaust, 4.10s, SCT flip switch
http://www.ok-safe.com/files/documen...JR1089_int.pdf Read it
Threads Similar to: How to Write up Comming!
Memphis folks, new tuner comming to town... 7-up man The Clubhouse 2 January 9th, 2008 04:27 PM
Leaking dont know where its comming from!!! Cantbeatblack 99-04 4 July 20th, 2007 08:15 PM
low coolant light keeps comming on. isenegger 5.0 Mustangs 12 April 29th, 2007 02:49 PM
Spring is comming.... jrfan4life Northeast 1 March 7th, 2007 08:15 PM
GOT A PROBLEM NEED HELP... I have red oil comming from ?? 91GRNGT 5.0 Mustangs 12 December 18th, 2006 08:57 PM
