1998 Ford Mustang GT
will i have an issue?
should i have any problems with my setup being blowthrough w/ pmas meter calibrated for 42 lbs. injectors and running 20 p.s.i. through a novi 2000 on a 98 gt with npi heads? what i'm concerned about is pushing that much boost with those size injectors, but being npi won't let me clear 450 rwhp, which is a good range for these injectors rated for 450-550. just wanting to know if i "NEED" to upgrade to 60 lbs. injectors or am i good with 42's.
are you talking about my mass air flow sensor, and why would i need to get it recalibrated?
1988 Mustang LX Turbo
disregard my last post, i didnt read the full post
42lb injectors are not capable of supporting 20psi
1988 LX Coupe 2.5L, GT35R, 44mm WG, 32psi, C16. |
so you don't think that 42 lbs. injectors will be able to support a supercharged engine producing 20 p.s.i. of boost through non p.i. heads even though the final power output to the wheels is within the horsepower range of the specific injector range? i.e., 42 lbs. fuel injectors will support from 450 h.p. to 550 h.p. and 60 lbs. fuel injectors will support from 550 h.p. to 700 h.p., etc.
another question is how does boost dictate fuel injector sizing even though you reach a certain h.p. level to the wheels? i thought once you've reached a certain power level, that would dictate which size injectors you would use. if i did decide to switch to 60 lbs. injectors would i have to have my blow through maf recalibrated or could i just use it even though it was sent to me calibrated for a specific size injector?
#9 | |
KB'd GT
SCT Flash custom tuning, XCal2, Datalogging, PLX Devices Widebands and gauges |
Threads Similar to: will i have an issue?
| idling issue | adrenaline=lifeline | 99-04 | 3 | June 8th, 2008 02:29 PM |
| brake issue again | 00redgt | 99-04 | 15 | February 8th, 2008 07:20 AM |
| Issue With Starting | JustinSane | V6 Mustangs | 6 | January 11th, 2008 07:56 PM |
| here is my issue | bigbadwollfff04 | Drag | 35 | July 5th, 2007 09:34 PM |
| t5 issue | 342stroker | 5.0 Mustangs | 3 | June 4th, 2007 09:41 PM |
