Supercharger For V6?
Old November 9th, 2006, 10:21 PM   #1
Easy04_jm's Avatar
Easy04_jm is on a distinguished road
Send a message via Yahoo to Easy04_jm
Will an stock engine....meaning stock heads and bottom end hold and super charger kit. The kit is on rpmoutlet.com it is under 94 and up v-6's thanks guys. Oyea its the one with the 11 psi pulley
!994 mustang with 96 3.8l engine. Ram air intake, Helix tower power throttle body space, dual exaust w/flowmaster's, 98 gt rearend 8.8 w/ 327 gears,SCT Xcalibrator 2 sf, and lots of audio and entertainment
Old November 10th, 2006, 03:02 AM   #2
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
if the kit is vehicle specific it will work. s/c manufactures build kits around a stock bottem end unless otherwise posted. do homework on superchargers before you buy one to be sure that you will be happy. a v6 will hold a s/c on stock bottom end, just be sure to set the boost at recommeded psi.
Old November 10th, 2006, 09:28 AM   #3
99mustang232's Avatar
1999 Ford Mustang V6
99mustang232 is on a distinguished road
would recommend upgrading to the 99+ 3.8L MLS headgaskets first, but the bottom end will hold it. might want to ask vmptuning about their kits since they offer a discount to moddedmustangs.com board members
...even fire and single cammin
1986 Ford F-150 5.0L 2WD
1994 Toyota Pickup 2.4L 4WD
1999 Ford Mustang 3.8L V6
2002 Jeep Grand Cherokee 4.0L 2WD
2008 GMC Sierra Denali 6.2L AWD
Old November 10th, 2006, 08:57 PM   #4
97TunedMustang's Avatar
97TunedMustang is on a distinguished road
Send a message via AIM to 97TunedMustang
like they said the stock bottom end will definately hold up to 11 pounds easy. the stock headgaskets however will go quick cause theyre crap. definately look into better ones as someone above me suggested.
95 Civic Ex, FnF1's, Morimoto Mini h1 retrofit,
GSR, bbk intake, BDL tb, 57trim t3/t4 8psi, 297whp
96 Civic Ex 2dr, G3 HID retrofit, FnF type 1's, Si cluster, Obd1 Z6 swap
Old November 10th, 2006, 09:40 PM   #5
Easy04_jm's Avatar
well ive already replaced them with felpro blues cause they had messed up on me already so are those gaskets good?
Old November 11th, 2006, 12:58 PM   #6
try the OE 99+ 3.8 Multi-Layered Steel Head Gaskets, you can get them from your local Ford Parts or off the net, they will hold the boost you are looking at... for a couple hundred you should be able to get all of the gaskets needed to change the heads, cam and intakes. I think RPM sells a topend swap kit, but not sure which headgaskets?
Threads Similar to: Supercharger For V6?
supercharger scubasteve041186 General Tech 3 September 17th, 2007 12:44 AM
supercharger 07AlloyPony V6 Mustangs 102 August 7th, 2007 10:46 AM
supercharger that will fit on a 302 and 351? nba1341 5.0 Mustangs 3 July 26th, 2007 05:22 PM
Supercharger? craigkoz00 94-95 3 February 6th, 2007 07:14 PM
Supercharger jes93 5.0 Mustangs 6 November 21st, 2006 07:53 PM
