Starting Question
Old November 10th, 2006, 01:38 AM   #1
trebel14's Avatar
trebel14 is on a distinguished road
Starting Question
Just picked up a 96 gt. And was hoping i could get some help here! When it has sat for a little while and i go and try to start it, it will crank over for a while then i let off then crank it again and it will start but takes a while to start. but after been driven and is warm it starts right up. what would be the cause of this? please help asap thanks
Old November 10th, 2006, 03:04 AM   #2
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
probably needs plugs wires filters and a little time to get used to being driven again.
Old November 10th, 2006, 03:30 PM   #3
trebel14's Avatar
ok i pulled out a couple of my plugs and they look fairly new, so i didnt replace them. i got a fuel filter, but didnt kno they were under the car so didnt have enough time to install it. I took my IAC off and sprayed carb cleaner inside of it and bolted it back on. Now i need to change my belt. can anyone give me any tips or how hard it is to do?
Threads Similar to: Starting Question
Bad starting Top Gear V6 Mustangs 30 September 14th, 2007 11:05 PM
Starting the car 92_LX_5.0 5.0 Mustangs 0 August 20th, 2007 05:37 PM
HELP! Car Not Starting!! fastford3388 5.0 Mustangs 1 August 3rd, 2007 10:36 PM
Stroker question/rough starting 65 B/FX Classic Mustangs 13 March 27th, 2007 12:50 AM
Head install question: Setting valves before starting? mikes93fox 5.0 Mustangs 3 August 28th, 2006 10:50 PM
