1999 Ford Mustang V6
Nitrous Works - "Top 10 N20 Mistakes"
THE TOP 10 NITROUS MISTAKES
1. Never heat a nitrous bottle with anything but an approved bottle heater with the proper safety features. If a nitrous bottle is overheated or heated too quickly, a catastrophic explosion can occur. (blow torch) 2. Never attach the power leads to a 12-volt nitrous bottle heater directly to the battery. Always use a 12-volt power supply that is hot (active) only when the ignition is on, making it a fail-safe installation. 3. Never allow liquid nitrous to touch your skin. Liquid nitrous exists at -125° F (-87.2° C), and exposure to it will cause severe and permanent frostbite damage. 4. Never inhale nitrous oxide. Inhalation can cause suffocation and immediate death. (this is not the same as medical nitrous oxide it contains sulfur) 5. Never leave the nitrous bottle valve open except when you are using it. Leaving the valve open for extended periods can damage the seals in the nitrous solenoids. 6. Do not exceed a bottle pressure of 1100 psi. The nitrous system is designed to operate at 1100 psi and exceeding that pressure can cause the engine to become too lean and cause extensive engine damage. Additionally, higher pressures can damage the solenoid seals. 7. Never assume that a stock fuel system is sufficient to meet the needs of your nitrous system and the engine. If a stock fuel system cannot supply enough fuel to the engine, the mixture will become too lean and severe engine damage will occur. 8. Never assume that fuel pressure at idle and wide-open throttle are the same! Always check the fuel pressure at wide-open throttle and under load. 9. Never use TeflonŽ tape on any plumbing threads in a nitrous system. A loose piece of tape could clog a solenoid or jet orifice. Always use TeflonŽ paste. 10. Never activate the nitrous system without the engine running. Doing so may cause an explosion on engine start-up. |
Number 11: Never let peformance unlimited fill your bottle
'96 Exploder XLT 5.0 AWD "turbos coming soon" |
#3 | |
Re: Nitrous Works - "Top 10 N20 Mistakes"
oh #12 dont let a bunch of angry asians on crotch rockets shoot up your lime green eclipse, cuz they will probably hit the nitrous and it could cause a "catastrophic explosion"
![]() A U D I //S4 2000 6MT/TT/AWD Stage 3 in the works.. 460+ awhp 455 lb/ft torque, 500+ awhp on race gas
#4 | ||
hey that blow torch thing is more common than you think, I have seen a few run a blow torch across the bottle a few times to warm it up on cold nights without a bottle heater.
kinda ironic but awhile back I used to work for the company who distributed the N20 tanks to Performance Unlimited so I have hooked them up in their NN and Norfolk shops... but didn't have anything to do with their training or filling of tanks... |
#6 | |
#7 | |
#8 | |
#9 | |
#10 | ||
#11 | ||
#12 | |
saw someone on pinks last night warmin up the nitrous with the blow torch
i wouldnt do it, blow torches are sooooo hott it could raise the pressure way too fast and get outta control.... i think ill play it safe
#15 | |
My Stallion is Bigger!
#16 | ||
![]() SEEYAAAAAAAAAAAAAAAAAAAAA MOTHER @#$% |
#17 | ||
Hi everyone, I thought I needed to say something about this topic. I was just telling a friend last week about heating aluminum cylinder's. The problem is aluminum cylinder's can't be heated past 350 F. Start's to take the strength out of the cyl.The paper's I read do not explain everything. P.S. I Hydro Test cylinder's for a living. Nitrous safety disc do blow out about 3000 PSI |
I see alot of fools use a hand torch to heat bottles. Hell, I've seen professional drag racers do it too. I think its pretty stupid myself.
#19 | |
RLY SRS
Just go buy a damn bottle heater and be done with it... |
these are probably the same hillbillies that build fires under their propane tanks. but at the top it says n20 contains sulfur?! to what degree this is the first ive heard of this. not to say its not true because i know little of what comes in those bottles. but i do know what sulfur does to metal. it will eat the shit out of.
Threads Similar to: Nitrous Works - "Top 10 N20 Mistakes"
| "Chrome Deep Dish Bullits" PICS Comments wanted... | mediaultra | V6 Mustangs | 17 | February 4th, 2012 08:19 PM |
| List of "unique" tools for Header install:Swivel S | Smoothgrandmama | 99-04 | 14 | October 19th, 2007 06:32 PM |
| Nitrous = "REAL" hp or not? | 96Snaker | The Clubhouse | 35 | October 16th, 2006 07:48 AM |
