88 GT With A Few Problems
ok, firstly, I am new to the site, I just found it about an hour or so ago.
ok I have a 1988 Mustang GT with a few problems, and I am wondering if anyone could give me guesses as to how much I'd be looking to spend on fixing it as well as, well, whats wrong with it. my passsengers side front steering assembly squeaks not only when I turn but also when I go over bumps. Now, the car has been ran off the road twice in its life, but thats a new thing that has developed after the running off of the road stuff. Also, the rear end whines on the drivers side, any guesses? it sounds like its close to the outside of the car, but I'm really not sure. My car used to be a manual but the people my parents bought it from switched it to an auto and I have no idea what kind it is. if it helps, the shift lever goes P R N OD D 1, and I've never seen one like that before. The heater core leaks, and I've been reading on here that its a pain in the ass, but at least now I know how to do that. My a/c doesnt work, my dad says its something with the vacuum pump clutch or something like that? maybe? and if anyone could give me in-depth directions on how to remove the center console, that would be awesome. The front u-joint on the driveshaft is bad but I have a new one to replace it The e-brake barely keeps the car from rolling at idle and I pull it as close to vertical as I can. also, since I plan on fixing all of these problems, I will list what I have on the car and ask to see what some of you recommend on getting for upgraded parts. I have: Aftermarket headers(not sure what ones, my brother might know since the car was his before it was mine) flowmaster 40 series mufflers stock 4 cat H-pipe K&N filter transmission has a shift kit but needs to be rebulit(hence why I need to know what kind of tranny it is)(or would it be easier and relatively close in price just to buy a rebuilt tranny?) 3.73's and Team Ford Racing spark plug wires(whoop-tie-doo) I also believe there are aftermarket suspension parts in play, I will ask my brother to get a definite answer. I was thinking about switching to a cold air intake with a new K&N filter, X-pipe, then cam, but I dont know what brands to look at or if it's even worth it for the trouble with everything wrong with it. so, any help would be much appreciated! Thanks, Nate |
1984 GT
13.21@104.61
Sounds like you have your work cut out for you. If you love working on cars ( like I do ) you will have lots of fun.
The first thing you need to buy is repair manual. Please don't think this is smart answer ..... A chiltons repair manual and a How To Modify Your Mustang were my first two purchases. Some of the things you described sound sound like simple maintenance. Have fun. .......... I did. jjg
Eibach Sportsline, Mac, Moroso,Comp Cams,PRW roller rockers, and no money left over. |
#3 | ||||||||
Re: 88 GT With A Few Problems
Thank you both, a Chilton's manual has been purchased as well as a K&N cleaning kit for my current K&N filter. Once I get the garage cleaned out, the car will be in there and jacked up checking the tie rod and ball joint for defects(my dad is rather skilled at such things) I dont have too much time on my hands so I will loop the hoses for the heater core and put on the u joint I have now and once spring breaks in comes an TFR aluminum driveshaft and new copper heater core. Hopefully, by funding of my dad, a new(or at least rebuilt) transmission will be on its way in to my fox asap as that was one of the first things that required attention. I know the a/c is not faulty due to the charge level as I have charged it myself many-a-time as well as my dad, my brother, and a local mechanic. I will not lie, I have no idea what the factory air silencer does, looks like, or where exactly it is, other than in the passenger fender well.
I'll mess around with getting the console off, I got the armrest off but I cant get the piece that goes into off, I cant find the screws. I will eventually though. Again, thank you both, I'll keep updates of how it's coming, and in the mean time, I am stuck driving a 4.3L blazer... |
Threads Similar to: 88 GT With A Few Problems
| 2.3L Problems. | akatagyourit | 2.3 Mustangs | 51 | June 25th, 2007 04:39 PM |
| problems plz help | cams-shelbycobra07 | 2005 - 2010 | 6 | June 14th, 2007 12:27 AM |
| more problems | ks_emt | 2.3 Mustangs | 7 | June 7th, 2007 04:16 PM |
| EEC IV problems | tekt | 5.0 Mustangs | 3 | February 19th, 2007 02:00 AM |
| Help Please (Car Problems) | 98mustang98 | V6 Mustangs | 1 | October 25th, 2006 11:49 PM |
