LinkBack (1) | Thread Tools |
#1
Checking Freon
My car A/C is not working...heat works perfectly but no cold air i want to check the freon but wheres it even located in the engine bay?
my car is a 1998 mustang v6 |
There is no freon in this car (after 96 all vehicles have to have r134 which is a refrigerant, not r12 which is commonly refered to as freon). The first step in a/c diag is to check for compressor clutch cycling. Open your hood find your compressor and see if it is cyclinng or even engaging at all. If it is cyling every couple seconds your refrigerant is likely low. If it is not cycling at all it is either and elecrical problem, clutch clearance problem or your refrigerant is low causing your low pressure/cycling switch to remain open and not allow engagement of you're compressor clutch. I would hate to say this but without gauges and a knowledge of a/c system operation it may be very hard to diagnose. If you have any more questions feel free to ask. The refrigerant can be checked by using both the low pressure and high pressure service ports to monitor both low and high pressure to properly diagnose the a/c being inop. Also duct temp can be a good indication. Another thing to check for is a plugged rad or condensor which will cause the high side to go too high which causes higher duct temps and h.p cutout. hope this helps
Certified Master Technician Also FORD certified -Auto Trans, Electrical and Electronics,Manual Trans and Differential,Diesel Engine Performance and Repair, Gasoline Engine Performance and Repair,Suspension, Climate Control and Brakes Specialist. |
#3 | |
MSTRB8N & MDR8N
2021 Mustang V15
Quad Turbo with nawz
MM 1 am boner crew Cars and mod list in garage i like veiny meat sliding between my buttcheeks |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/general-tech/83465-checking-freon.html
| Checking Freon | This thread | Refback | August 8th, 2008 10:20 AM | |
Threads Similar to: Checking Freon
| Just checking in | UrbanRedneck | New Members Introductions | 6 | April 19th, 2011 08:39 AM |
| Checking my MPG | Safi | The Clubhouse | 19 | July 2nd, 2008 07:47 PM |
| Freon? | Iwannagofast | 5.0 Mustangs | 21 | March 25th, 2008 03:49 PM |
| Just Checking In | Scrapdaddy SR. | New Members Introductions | 7 | May 16th, 2007 03:37 PM |
| Freon for 87 GT | cobralini | 5.0 Mustangs | 7 | July 15th, 2006 02:57 PM |
