Granatelli Motorsports Upper/Lower Control Arms
Anybody ever install these? If so how'd you like them?
Bart 93 Black on Black GT Kenne Bell S/C ![]() GIVE 'ER! |
Which ones? They make a couple different types.
The non-adjustable tubular ones. They can be found here:
http://www.granatellimotorsports.com...ontrolarms.htm http://www.granatellimotorsports.com...ontrolarms.htm Thanks.
never installed them, but if you are wondering how difficult it is.....if you have any mechanical experience then you should be able to do it yourself easily. i'll be doing the install of springs, shocks/struts, lca's, ext. on my 07 GT. the only thing i'll pay to have done is the alignment
The adjustables or the non adjustables? Either one works good and isn't very hard to install. The adjustable need to be set equal on the bottom to keep the tires centered in the wheel well and keep the track straight. The uppers are used to set pinion angle and preload. For a car that is pretty much a street only car that only gets raced occasionally the non adjustable control arms are all you need.
Thanks - I ordered the non-adjustable version, as I'll be doing more road racing than drag.
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
i have the non adjustable set up and i am pleased with them. for the price i have to say that they are damn good. they feel very connected and did wonders for cornering.
I'll be puttin all the stuff I bought over the winter on the car as soon as the weather starts to warm up - I knew I should'a put a woodstove in my garage!
Threads Similar to: Granatelli Motorsports Upper/Lower Control Arms
| For those with Upper/Lower Control Arms... | the real shocker | 99-04 | 26 | September 19th, 2007 05:49 AM |
| Upper and Lower Control arms! | MustangMatt96GT | 96-98 | 10 | June 28th, 2007 02:40 PM |
