Larger rims on my '08 V6 Mustang - Forums at Modded Mustangs
post #1 of 5 Old August 25th, 2008, 03:15 PM Thread Starter
Look Ma! My First Post!
I have a brand new 2008 Ford Mustang. It came stock with 18" rims and I'm looking for something larger. What is the maximum rim size I can use without having to modify anything else? I also don't really know much about tire sizes. I'm assuming I'm going to have to go with low profile tires if I'm getting my rims any larger. Any input/recommendations would be greatly appreciated. Pretty much everything else about the car is stock.
Kalias is offline
post #2 of 5 Old August 30th, 2008, 07:02 PM
Rollin' 18/ pushin' 2
97S281's Avatar
iTrader: 18 reviews
go to your ford dealer and look at a rousch or saleen. they run 20's. you can get the tire size from one of them. they will have to be very low profile though, like 35 or lower.
255/40/zr18.
the first number refers to the tread width, 255
the second number refers to the sidewall height, 40.
the letter is the tires speed rating, zr.
the last number is the rim size, 18.
a wider rim can hold a wider tire. I don't know how wide you can go on the newer model though.
MODS IN GARAGE
All SVO'D UP
97S281 is offline
post #3 of 5 Old August 30th, 2008, 07:03 PM
97S281's Avatar
iTrader: 18 reviews
if you post this in the 2005+ section you will probably get alot more help with rim suggestions and they will more than likely have some pics for ya.
MODS IN GARAGE
All SVO'D UP
97S281 is offline
post #4 of 5 Old August 31st, 2008, 02:06 PM
One Man Wolf Pack
06RedfireGT's Avatar
I wouldn't run anything bigger than a 20 inch rim.
Figuring 20x9 and 20x10 rim size, good tire sizes are 255/35-20 front and 285/35-20.
Good tires are Nitto NT555 and BFG KDW NT.
ΜΟΛΩΝ ΛΑΒΕ
06RedfireGT is offline
post #5 of 5 Old September 11th, 2008, 03:52 AM
This really depends on the car, if it will run smoothly. Big rims are great but it will cause some problems to your car soon. 18-20" would be the best I guess.
____________________
Autopartswarehouse is a must!
kisses is offline
Human Verification
You may not post new threads
You may not post replies
