Supercharger OR Turbocharger
aight so i got a gt and i want LOTS of horspower.... and i dont know wut to go with... a turbocharger or supercharger...??? wut would be best 4 me and if theres anything u think i need with 1 of them feel free to suggest...
thanks |
1990 GT
i say supercharge it and get forged internals so u can turn the boost up. theres a lot of kits out there that come complete with everything to install the s/c
1990 5.0 getting all fixed up for next season 2004 mustang gt 520rwhp, 491 trq sold
wut r forged internals? sorry for the newbie ?'s. and how would u turn up the boost?
if you want big numbers, turbo is the way to go. better build that block 1st though.
turbo man.
aight and wut kind?
and do i needa buy a kit? and wut will i need?
I am partial to HP Performance's Kit but that is just me google turbo mustangs and see what you like. Hellion also has a good kit. But to answer your question yeah I would buy a kit the HP kit can be ran on your stock engine as long as you keep your boost under 10psi HP has a car on their site with a stock engine 132000 miles running 9psi making 442 hp not sure on the tq numbers but high 500's but you want a kit man it has everything you will need minus the tune at your local shop. Now rebuild your engine with all forged internals and well have fun and boost the hell out of it go for 15 to 20 depending on your needs and driving style orthe blocks shape and all that if you ask me on a street/strip car 500-600 is good with gears and tires and all the other goodies you got a badass car. So if you haven't gotmy point yet I am a huge turbo fan man only recently the more I read on turbo's the more I like them. Good luck man I wish you the best.
94 Mustang Gt Cold Air Intake Header back exhaust H-Pipe Flowmaster Mufflers MSD Dist UPR upper and lower control arms UPR sway bar all spherical bushing in rear on the way HP Turbo Stage II Kit 331 Long Block |
ok when u say boost. is that the same as psi? so i want 15 to 20 psi and i jus tell them to tune it like that? and also wut does stage 2 and stage 3... and all those stages mean? so difference between psi and boost...???
stages dont really mean anything, there just obscure numbers a company puts on a kit to make it seem like its better or gonna make more power..
boost is just an other way of saying turn turn up your boost/psi, its just car lingo. psi doesnt matter either, it depends more on the size of your turbo. a t25 is gonna produce less power on 10 psi in comparison to like a GT42r on 10psi |
1999 Ford Mustang V6
i guess it is also all in what's your idea of fast? what kind of power are you looking for under or over 500?
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
#12 | |
dude boost is the increased amount of airflow your engine gets from the supercharger or turbo. psi is how its measured. psi = pounds per square inch. go to www.turbochargedpower.com and have a look around,kick back watch some sweet vids,and see if thats what you want. If so,go for it. good luck
Nobody gonna take my car Im gonna race it to the ground Nobody gonna beat my car Its gonna break the speed of sound Oooh its a killing machine Its got everything Like a driving power big fat tires And everything - Deep Purple |
i hated my supercharger, i went to turbo.. you always have to worry about slipping and breaking belts ... it drove me crazy
OK...Let me break it down....
First off... I dont reccomend trying to make anything over 400hp without forged internals. Forged internals are forged rods, pistons, and sometimes crankshaft to increase bottom end strength. Too much boost on the stock internals could break something fairly quickly. Second. Supercharging and Turbocharging are "VERY" different number-wise. If your looking for a lot of low end power and torque, you'll want a twin screw supercharger. If you prefer your power and toque to be higher up in the RPM range the you'll want a centrifugal supercharger. Superchargers are usually cheaper than turbochargers, and are generlally much more predictable. Turbochargers, on the other hand are a bit more complicated. Small turbos spool very quickly on high compression motors, but they put a lot of stress on internals. Larger turbos on lower compression motors are often better for your internals, but they dont reach peak boost as quickly. Turbo kits are generally much more expensive for mustangs than superchargers, but you get what you pay for. They're better at producing power and most of all torque. You want a sh*t load of torque, then get a turbo. Just a side not though. 400, 500, and 600hp is a lot more power than a lot of people think it is. A 600hp goal is a "BAD" goal for someone who still has yet to experiece what 400 or 500hp is like. FOrged induction isn't the best "FIRST" mod. Im only 17, but my dad has a modded gt with 330rwhp and I'll admit, it's too much for me, and it's a naturally aspirated vehicle (no turbo or supercharger). I can't control t. It's got more torque than traction. And that's just in the 300-400 range. I can only imagine what 600 is like. But I hope that helps. |
turbo it. ive seen twin turbo full size pick-ups run low 10's. on 8lbs street tune. thats why i decided to head that direction.
#17 | |
hellion is good, but not the best.
Hey stangaddiction...THANKS. Excellent comments. To ad to his comments, power adders ALWAYS find the weakest point. At those HP levels the next thing is the clutch, followed by the transmission, followed by the rear end and axles/suspension. Parts are gonna break.
Ron |
Threads Similar to: Supercharger OR Turbocharger
| turbocharger sizes | BWAL | General Tech | 26 | May 8th, 2008 08:42 PM |
| Supercharger OR Turbocharger | trueballerisme | V6 Mustangs | 150 | April 24th, 2008 01:16 AM |
| Supercharger & Turbocharger | Fox-DR1FTer | Modular Mustangs | 37 | November 1st, 2007 01:11 PM |
| Supercharger or turbocharger | EZ05 | Modular Mustangs | 16 | August 3rd, 2007 09:19 PM |
| turbocharger question | trueballerisme | General Tech | 24 | February 23rd, 2007 10:56 PM |
