100 shot????
Old November 19th, 2008, 06:31 PM   #1
Garrett's Avatar
1998 Mustang gt
Garrett is infamous around these partsGarrett is infamous around these partsGarrett is infamous around these parts
Send a message via AIM to Garrett
100 shot????
I have a stock 04 engine in my 1998. the only mods are spec flywheel and stage 1 clutch. x-pipe and 40 series flowmasters.
Would a 100 shoot nitrous set up be a smart things to do? Of course I'm going to wait till I have put some miles on the mustang seeing I just got the new engine put in. But would I be taking a high risk? would I be risking blowing the engine? I wont get on it all the time may ones or twice I month and then when June comes i might get on it a little more seeing its mustang week down here in myrtle beach.
Please let me have some good advise on what to do...I'm clue-less!
myspace.com/garrettstarnes
2004 4.6 engine.
Cold air intake.
Stage2 clutch.
Spec Flywheel.
Intake spacer.
Throtle Body spacer.
More to come!
Old November 19th, 2008, 07:08 PM   #2
rk_2000_Z/28's Avatar
2003 SVT Cobra
rk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of light
First, you will not be in danger but there are some things you need to do.
Some people are going to give you different advice and tell you that with such and such size shot than you need such and such upgrade, but anything smaller and you will be fine, blah blah blah.
In my opinion, ANY TIME you add nitrous than you need to find some way to keep an eye on your A/F ratio. If you run lean than you run the risk of blowing something.
You can do this with either some dyno time or a guage. Honestly, if it was me, even though a 100 shot isn't too big, I would still get it dyno tuned.
If it does end up running lean than a tune can get it fattened out. You may be pushing the stock fuel system so a new fuel pump might be in your future. Also, I think a fuel pressure safety switch is a must for basic nitrous systems. They are like $60 and a good insurance.
03 Cobra-Slow
02 SS, 00 Z/28-Gone
Rest In Peace Travis Billings
Old November 19th, 2008, 09:39 PM   #3
Garrett's Avatar
1998 Mustang gt
thanks for the information!!!
2004 4.6 engine.
Cold air intake.
Stage2 clutch.
Spec Flywheel.
Intake spacer.
More to come!
Old November 19th, 2008, 11:00 PM   #4
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
100 shot will be fine, make sure you get a tune, and pull a bit of timeing as well as dial in your a/f. a wet shot would be easier on your fuel system, you will want a both a window ans a WOT switch unless you get one integrated together (which I would do). also a wideband will be your best friend. you should be fine though, just dont spray below 3k rpm and when not at WOT. And dont hit your revlimiter on spray
NCMM #9
Old November 20th, 2008, 12:53 AM   #5
Garrett's Avatar
1998 Mustang gt
okay sounds great, I just don't want to blow the engine up because I know I wont be able to afford a new one.
Its something I def. wont to look into getting when I get a some miles on the car when the engine is broken in really good.
2004 4.6 engine.
Cold air intake.
Stage2 clutch.
Spec Flywheel.
Intake spacer.
More to come!
Old December 7th, 2008, 02:12 PM   #6
Bryan99hoss's Avatar
Bryan99hoss is on a distinguished road
yeah spray below 3K = new bottom end
Old December 15th, 2008, 01:20 PM   #7
WHOOP!
AggieStang's Avatar
7.44@95 (1/8)
AggieStang is just really niceAggieStang is just really niceAggieStang is just really niceAggieStang is just really niceAggieStang is just really nice
+1
Buy my:
Nitrous Accessories
Diablosport Programmer
In The Classifieds
Threads Similar to: 100 shot????
5 shot-100 shot ricerraper33 V6 Mustangs 2 July 17th, 2008 06:14 PM
12.5 with just 100 shot.... DeMello The Clubhouse 26 May 22nd, 2008 01:38 PM
100 shot? 5.0 smoke em 5.0 Mustangs 15 December 26th, 2007 09:54 AM
100 shot dry itschristorres8 General Tech 40 June 18th, 2007 02:54 AM
