k member install
Old December 22nd, 2006, 01:07 PM   #1
droppedbass87 is an unknown quantity at this point
Send a message via AIM to droppedbass87
k member install
hey guys im thinking of going with a new light weight k member...do i have to change everything to coil over and if so what exactly does coil overs do??and can i go ahead and change my shocks right now before i do all this??
Old December 22nd, 2006, 07:14 PM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
No you don't have to change to coil overs. Most companies offer them with or without spring perches.
Old December 23rd, 2006, 05:13 PM   #3
ok good cuz i just want to lighten up the fron end..
Old December 24th, 2006, 11:59 PM   #4
99mustang232's Avatar
1999 Ford Mustang V6
99mustang232 is on a distinguished road
great way the lighten the front end, where you going with tubular a-arms?
...even fire and single cammin
1986 Ford F-150 5.0L 2WD
1994 Toyota Pickup 2.4L 4WD
1999 Ford Mustang 3.8L V6
2002 Jeep Grand Cherokee 4.0L 2WD
2008 GMC Sierra Denali 6.2L AWD
Old December 25th, 2006, 05:49 PM   #5
MM's nicest mod, :)
White99stang's Avatar
White99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to all
there are many kits you can get, some have the tubular a-arms with spring perches, you can get some that can use the stock a-arms, and you can get the full kit with coil-overs. You can go ahead and get struts now for the front but if you get coil-overs you might have to modify the struts, by grinding down the dust caps on top or cutting them off. I have the UPR tubular k-member with coil overs and i love it. I just took my lakewood 90/10 struts to a grinder and grinded off the edges of the dust caps so i could fit the sleeves over them and it was good to go from there. Its a pretty fun task installing it also lol.
06 Dodge MegaCab Diesel 455rwhp/815rwtq
REAL TRUCKS DON'T USE SPARK PLUGS
Threads Similar to: k member install
GMS Mustang Tubular K member Kit w/ A-arms, K member, & 94GTD1SC Drag 1 November 16th, 2007 12:11 AM
New Member considering an 07/08 GT GodWhomIsMike New Members Introductions 5 July 7th, 2007 11:17 PM
New Member, But Old... czwalga00gt New Members Introductions 8 November 9th, 2006 08:10 PM
New Member dapack69 New Members Introductions 18 November 8th, 2006 11:50 AM
Tubular K Member Install droppedbass87 General Tech 27 October 15th, 2006 04:31 PM
