CornerKiller™ IFS Systems
Go Back   Forums at Modded Mustangs > The Marketplace > Authorized Vendors > Helix Suspension, Steering & Brakes
Old May 27th, 2009, 09:49 PM   #1
kris@thehoffmangroup is an unknown quantity at this point
Helix Corner Killer RX™ Front Suspension gives you a much smoother and softer ride than a 4-link dropped axle at a comparable cost. It adds more value to your car than any other type of suspension. And with Helix engineering you get an unmatched, geometrically correct, safe ride. These kits fit frames easily, provide a 3-4" suspension drop, and are pre-notched with no cutting or trimming required for easy, hassle-free installation. All kits include the necessary brackets and mounts needed to complete the installation, plus Helix’s™ own detailed and illustrated step-by-step installation manual. Comes with a Limited Lifetime warranty and International Tech Support from certified technicians that are available to help you from start to finish. Helix’s Corner Killer RX™ complete system is perfect for the ultimate stance! The Corner Killer RX™ arrives complete from hub to hub. Helix’s™ unique packaging system allows us to ship through common carriers such as UPS™, FED EX™, or USPS.
* Adjustable Control Arms :: Adjustable tubular control arms. Plain steel or polished stainless steel. Stock or narrowed width. Stainless steel adjusters with urethane bushings.
* CrossMember :: Precision T.I.G. Welded for maximum strength and great looks.
* 2" Drop Spindles :: Our one piece stock or 2" dropped spindles are made from 1045 heat treated alloy steel, not cast like our competitors’, which are prone to breaking. Manufactured for safety and performance for your comfort and peace-of-mind.
* Brakes :: 11" Disc brake vented rotors (choose either Ford or Chevy bolt pattern).
* Steering :: Manual or power rack & pinion steering. Factory ball joints and tie rod ends. No bump steer and 4° of anti dive built in. Adjustable coil-over shocks with chrome springs
* Adjustable coil-over shocks :: Our coil-over shocks feature chrome springs and 10-point dampener adjustability for the ultimate in precision ride qualitquality.
BUILD YOUR IFS KIT TODAY
Threads Similar to: CornerKiller™ IFS Systems
alarm systems? 00mustang00 99-04 7 October 6th, 2008 11:48 AM
Security Systems GTsetGO The Clubhouse 15 June 22nd, 2008 05:05 PM
Procharger Systems V6 Stalker V6 Mustangs 7 March 30th, 2008 08:32 PM
Heidts Suspensions (IFS Front, 4-bar Rear) Your Thoughts? 66 FSTBK RR Classic Mustangs 5 January 23rd, 2008 06:15 PM
Exhaust Systems... bcp5008 V6 Mustangs 15 September 5th, 2006 12:16 AM
