Discussing Mustang II IFS Systems in the Helix Suspension, Steering & Brakes Forum. Helix's™ Mustang II IFS Systems are a natural conversion for your chassis, giving you a ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Authorized Vendor
![]() Join Date: May 2009
Mustang II IFS SystemsHelix's™ Mustang II IFS Systems are a natural conversion for your chassis, giving you a soft, smooth ride. We retain all the factory dimensions and locations, so you get all the benefits of Ford engineering in your front end. These kits fit frames easily and yield a 3"-4" suspension drop. Pre-notched with no cutting or trimming required. Included in most kits are all the special, hard-to-make brackets and mounts you will need to complete the installation, plus Helix’s own illustrated step by step installation manual.
Mustang II Suspension Packages are available in both Deluxe and Economy versions, and both are available with or without crossmembers. Deluxe packages include plain tubular upper and lower full A-Arms, crossmember with all welds ground while Economy packages include crossmember with ungrounded welds. All packages include: 11" five lug rotors; bearings and seals; springs; stock spindles; calipers with brackets and pads; manual rack and pinion with tie rod ends and bushings, rubber spring cushions, spindle nut kit, and all mounting hardware. Comes with a Limited Lifetime warranty and International Tech Support from certified technicians that are available to help you from start to finish. Customize your Mustang II IFS System TODAY ![]()
Threads Similar to: Mustang II IFS Systems
| CornerKiller™ IFS Systems | kris@thehoffmangroup | Helix Suspension, Steering & Brakes | 0 | May 27th, 2009 09:49 PM |
| Security Systems | GTsetGO | The Clubhouse | 15 | June 22nd, 2008 05:05 PM |
| Shelby Gt500 Fuel Systems Back In Stock Direct Plug & Play For 2005-08 Mustang Gt's | MMP, Inc. | Muscle Motors Performance | 0 | January 24th, 2008 11:31 AM |
| Heidts Suspensions (IFS Front, 4-bar Rear) Your Thoughts? | 66 FSTBK RR | Classic Mustangs | 5 | January 23rd, 2008 06:15 PM |
| Exhaust Systems... | bcp5008 | V6 Mustangs | 15 | September 5th, 2006 12:16 AM |
