24lb Injectors for only $99.99 per set!
LIMITED SUPPLY!!!!
We came accross a great deal on an overstock of these FRPP 24lb injectors. They are the EV6 type small body injector with the USCAR (new style) connector. However, we paired them up with the proper adapter plug so that you can use these 24lb Injectors in your 86-04 Mustang 5.0L, 5.8L, & 4.6L 2V! The kit includes 8 24lb injectors & 8 USCAR to Jetronic harness adapter plugs. Make sure & pick up your set today as these will not last long!!!! Mustang 24lb Injector Kit |
They're all gone! Thanks folks, we do appreciate it.
Threads Similar to: 24lb Injectors for only $99.99 per set!
| 24lb injectors | worlz08 | 5.0 Mustangs | 4 | June 13th, 2008 05:27 PM |
| 24lb injectors? | shaunnj007 | 99-04 | 10 | February 12th, 2008 06:21 PM |
| Do I Need 24lb Injectors? | 88dragstang | 5.0 Mustangs | 10 | November 23rd, 2007 01:43 PM |
| Will Not Run On 24LB Injectors | Euroeater95 | 94-95 | 5 | November 4th, 2006 10:24 PM |
