finally got air filter
Old December 27th, 2006, 11:51 PM   #1
FastBack71 is on a distinguished road
Ok so i finally go the bbk cold air intake today, and in 4 days i should be getting the xcal with the tune.. Can i run the cold air intake for 4 days without reflashing? is it dangerous ?? will it be ok or should i just wait
Old December 28th, 2006, 12:15 AM   #2
03 Mustang GT Twin Turbo
10.43 @ 139mph
WAVEBYE is on a distinguished road
Send a message via AIM to WAVEBYE
i put mine on and never touched the ecu until i put the blower on. all i had was o/r exhaust and a mac CAI,in fact the day i put the CAI on i went straight to the track after i finished it.
Nobody gonna take my car
Im gonna race it to the ground
Nobody gonna beat my car
Its gonna break the speed of sound
Oooh its a killing machine
Its got everything
Like a driving power big fat tires
And everything - Deep Purple
Old December 28th, 2006, 12:22 AM   #3
did it respond well to just the cold air intake?
My friends used to wonder Why i joined the air force. Now they wonder why they didn't.
Old December 28th, 2006, 12:53 AM   #4
mach03 is on a distinguished road
If what you bought states that it requires retuning,
wait for the tuner.
Differant kits have differant parts and requirements I don't memorize everything, but if you change the amount of air through the meter w/o calibration it can be bad.
Old December 28th, 2006, 07:31 AM   #5
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
just adding a CAI wont hurt anything. the computer will read and adjust on its own. with all the bolt ons a tuner is not required but will help bring full potential out of them. when you get to really messing with fuel/air delivery then it will be required. (ex. boost, injectors, nitrous if you want to tune to that, etc.)
Old December 28th, 2006, 11:12 AM   #6
Sweet2kstang, if you use a kit that has a larger bore maf housing but reuses your stock sensor a tune is needed because you will max out the sensor, also it will create issues in the calculations inside the ecu, trying to figure out mixture control.
So I stand firm, if the kit says you need to tune it, do it.
it's not worth damaging an engine for 10 hp.
Old December 28th, 2006, 08:37 PM   #7
MustangMatt's Avatar
2009 427R Roush
12.39
MustangMatt is on a distinguished road
Send a message via ICQ to MustangMatt
Sweet2kstang is talking about his 02 stang. On a 05 and up, if the kit says it requires a tune it is due to the car running too lean after the CAI is installed. So if you do drive it without the tune and it requires it your engine could be hurt, but it could also go into limp mode and would run very poorly and not allow you to really drive it. Limp mode is basically designed to get you to a repair shop. I would say don't put it on until you have your tuner (if it requires a tune) Just my opinion. But it would suck to hurt your motor and risk your warranty over only a few more days of waiting.
2009 427R Vert 3.73's, Roush Big Brake Kit
Old December 29th, 2006, 03:13 AM   #8
1999 Mustang
Invictus is on a distinguished road
no tuning is required for a CAI, you probably wont notice any gains either, especially if this is your first bolton
Old December 29th, 2006, 08:15 AM   #9
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
if you run a larger MAF when its not needed then you are an idiot! all vehicle specific kits are made to work on a factory car that means no tune required! if that unsure about it call the manufacture you got it from. i have yet to find a direct replacement CAI that has to have a tune
Old December 29th, 2006, 02:40 PM   #10
He didn't say he went with direct replacment or a full on kit with meter ect.
he mentioned he had a tuner on the way. If he has a full set up with a new sensor ect. I was suggesting he simply follow what ever the manufaturer recomended. If no tune is recomended fine, but if it is there is a reason.
Old December 29th, 2006, 04:06 PM   #11
wow so i go to put it on and they didn't give me the right stuff.. american muslE??
Threads Similar to: finally got air filter
Need help with the K&N air filter!! 92stang0802 2.3 Mustangs 17 September 19th, 2007 09:33 PM
K@n air filter VanHall 99-04 4 April 30th, 2007 11:37 AM
k/n filter RedStangGT 99-04 45 April 27th, 2007 03:32 AM
Oil filter Ryno 99-04 19 January 26th, 2007 12:19 AM
