Porting Stock Plenum and TB
So I have an extra throttle body and plenum.... and a machine shop at my school...
Would porting them make any big difference? Are there any websites that can show me how to do this? Or the specs that it can be made to? Thanks
![]() Cammed 2v Built By MustangMatt More mods than times your daughter has slept around |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
there are gains to be had porting them. i ran a ported plenum and t/b for a while. if done correctly, they will flow competively with an aftermarket set up.
12.73@111.36
Don't enlarge the area around the butterfly valve. If you do you won't be able to cut off the air flow to the motor and could end up with a 2000 rpm idle.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
mm's nitrous mod
2000 mustang gt
i can sell ya a ported set up if you would like.
#5 | |
Rollin' 18/ pushin' 2
+1 , I had this problem with a setup I bought off ebay.
i port them now and then. It's less about material removal than it is about building up the floor on the short side turn of the plenum with some epoxy. I use a sanding wheel and a drill to enlarge the throat. Don't bother porting the TB... it's easy as hell to mess it up and you'll get nothing for it. It's better to get a 70mm or 75 (if supercharged) TB and bolt it up to a properly ported plenum.
mm's nitrous mod
2000 mustang gt
its easy to port the t/b, hard to mess up if you are paying attention. usually on a mild car the ported t/b does nothing, i have done one on an tuned bolt on auto with damn good results.
Threads Similar to: Porting Stock Plenum and TB
| Porting the stock throttle body | BlckBullitt01 | 99-04 | 8 | June 9th, 2008 05:01 AM |
| Stock head and Intake Porting | GizmosMustang | 5.0 Mustangs | 21 | May 3rd, 2007 10:29 PM |
| porting stock intake manifold | 99GT281 | 99-04 | 10 | March 22nd, 2007 08:39 PM |
