Trans Fluid
LinkBack (1) Thread Tools
Old January 26th, 2009, 06:35 PM   1 links from elsewhere to this Post. Click to view. #1
2004 Mach 1
bigtom is on a distinguished road
Send a message via AIM to bigtom
Trans Fluid
What trans fluid should i use for the TR3650 in the mach? I heard people saying not to use royal purple and some say to use. The locally tranny shop has no idea what to use. im having a hard time going into 3rd. and he said it might need a fluid change. also how much fluid is needed? So what would be good
Old January 26th, 2009, 06:37 PM   #2
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
3.3 qts. of Mercon 5 ATF
Old January 26th, 2009, 06:37 PM   #3
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
I used Valvoline btw...
Old January 26th, 2009, 06:44 PM   #4
2004 Mach 1
does if matter synthetic or conventional
Old January 26th, 2009, 06:46 PM   #5
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
I don't know. I think Mercon 5 ATF is synthetic
Just use Mercon 5 ATF
That's what it says on All-Data.
Old January 26th, 2009, 06:50 PM   #6
2004 Mach 1
ok thanks
Old January 26th, 2009, 07:43 PM   #7
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
No prob. man
Old January 27th, 2009, 01:10 AM   #8
qwik48r's Avatar
alotta shit
no fat girls fast
qwik48r is a jewel in the roughqwik48r is a jewel in the roughqwik48r is a jewel in the rough
Send a message via AIM to qwik48r
cheap stuff..... seriously
mind your business what i drive... i'm on a fucking mustang forum.
qwik's build
Old February 1st, 2009, 04:13 PM   #9
2004 Mach 1
i put in 3.5qts. of mobile 1
Old February 3rd, 2009, 07:38 PM   #10
rOnstanG281's Avatar
2004 40th anie mustang GT
Dont no
rOnstanG281 is on a distinguished road
i have the same trans mission in my Gt shud i use the same im also noticing my gears aint as smoothe as they once were can i do this my self or is it like putting oil in it?
i no im new and dum
Old February 3rd, 2009, 08:38 PM   #11
03MachMe's Avatar
2003 Mach 1 Mustang
03MachMe is on a distinguished road
use EXACTLY 3 LITERS. they changed the amount in late 05 or something like that. and use conventional. synthetic will wear down the syncros faster. just use some mercon V or dextron III either will work. might want to put some of the lucas oil tranny fix in as well the guys over on the registry swear by it. and when i changed mine not to long ago i could def tell a difference. check out the registry if your not on there LOTS of good info for your mach.
mostly stock
8.2@83 1/8th
Old February 3rd, 2009, 08:42 PM   #12
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
Do you have a good source of info for that?
I'm not coming off as offensive.. really wondering.
Old February 3rd, 2009, 08:43 PM   #13
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
casper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant future
synthetic is a no-no in 5spd's. dont know about the wear thing but it's too slippery for the syncro's to work well. might be ok granny shifting on the street but next time your at the track mention to some track regular mustang guy that your having problems power shifting (just for example) & the first thing he'll say to you is "you don't have synthetic in there do you ?"
MM BRACKET RACING CREW CO-FOUNDER
BAMA Performance Drag Team Founder
2012 300a GT auto
Old February 3rd, 2009, 08:47 PM   #14
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
ALLData calls for 3.3qts of any Mercon 5 ATF for the 3650.
Old February 3rd, 2009, 08:51 PM   #15
03MachMe's Avatar
2003 Mach 1 Mustang
i had the document from tremtic that said 3L im not sure how many qts that is but thats what it said
edit: here is something like what i had
http://www.paladinmicro.com/document...id-04-15-6.pdf
read number 6
mostly stock
8.2@83 1/8th
Old February 3rd, 2009, 10:37 PM   #16
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
read number 6
I do 3.3 because of what all data says. I trust the TSB's on there more than Tremec (don't ask why I just do). But even 3 should be fine. I don't see a problem w/ 3 qts. So basically; anywhere from 3.0-3.3qts.
Old February 3rd, 2009, 10:54 PM   #17
03MachMe's Avatar
2003 Mach 1 Mustang
3L is like 3.12XXqts or something like that
mostly stock
8.2@83 1/8th
Old February 3rd, 2009, 11:06 PM   #18
2004 Mach 1
so i should take out the synthetic then. i read that tremec recommends gm synchromesh for the 3650
GM Syncromesh
Old February 3rd, 2009, 11:07 PM   #19
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
This is what I use:
Old February 3rd, 2009, 11:11 PM   #20
2004 Mach 1
http://www.mach1registry.com/images/...eTopic3-02.pdf
LinkBack to this Thread: http://www.moddedmustangs.com/forums/modular-mustangs/107366-trans-fluid.html
Everything about mach 1 registry - Yahoo! Glue This thread Refback February 16th, 2009 12:29 PM
Threads Similar to: Trans Fluid
adding trans fluid to t-5 fastford3388 5.0 Mustangs 17 June 6th, 2008 04:17 AM
Trans Fluid Change 90Stang 2005 - 2010 0 March 10th, 2008 10:55 PM
1966 Mustang trans fluid MustangJon255 Classic Mustangs 13 August 13th, 2007 04:46 PM
What Kind Of Trans Fluid For A T45 wolffer 96-98 2 September 12th, 2006 09:31 PM
how much trans and diff fluid militarygt General Tech 8 July 23rd, 2006 01:08 AM
