P0174:dpfe Sensor???
Old February 14th, 2009, 01:05 AM   #1
1999 mustang Cobra
knightof206 is on a distinguished road
Recently i had 2 codes pop up and i have 3 total, one is cuz i have no cats, another is my coil was bad, i replaced the bad coil and replaced all spark plugs.
but code P0174 is sticking around, i cleaned my MAF with electronics cleaner and it didnt fix it, i can notice that something is wrong to cuz there a smell that is awlays around since it happend and it puts a horrible taste in my mouth and my idle jumps around a lot. what should i replace next?
Lowered, Magnaflow o/r X pipe, Magnaflow MagnaPack Catback, JLT CAI, Livewire Tuner
Old February 14th, 2009, 10:14 AM   #2
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
It's because you're running lean. You might have a leak somewhere.
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Old February 14th, 2009, 02:03 PM   #3
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
^that be it, do you have MIL eliminators on since you dont have cats? also take your DPFE sensor off and make sure that there is no water in it. there have been instances that ive read where there was water in their DPFE and causing codes to throw, also check your hoses. the DPFE, BTW, is on the bolted onto the back of the intake manifold and there are 2 hoses and 1 plug running into it.
BUILD 2 IN PROGRESS
Old February 14th, 2009, 07:20 PM   #4
1999 mustang Cobra
also i set my tuner to show me my fuel trim in and bank 1 was always around 1.00 but bank too was always 1.20 or higher if that means anything
Old February 14th, 2009, 08:13 PM   #5
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Check for an air leak on the left side near the midpipe/header connection.
Old February 14th, 2009, 11:10 PM   #6
1999 mustang Cobra
i do have partially welded in straight pipes for Cats and i recently broken off my muffler connection from going over a hill to fast and landing. should i have my O2 connected or not?
Old February 16th, 2009, 07:32 PM   #7
Trick Tuners's Avatar
KB'd GT
If the fuel trim ever stays right at 1.0 then the tune is way out of calibration and its switched over to open loop because it thinks the sensor is bad. Considering that the other bank is high too i would assume that this is the case. Its possible that bank 2 has a header leak, or bad o2 sensor. I would contact your tuner and have them dial the tune in better.
Old February 17th, 2009, 01:07 PM   #8
1999 mustang Cobra
also on my tuner it shows my MAF voltage as n/a, does that mean my MAF is out or can the tuner just not detect that?
Old February 17th, 2009, 02:00 PM   #9
KB'd GT
try using maf counts instead of voltage.
Old February 18th, 2009, 02:44 PM   #10
1999 mustang Cobra
i fixed it i replaced the O2's and cleaned the MAF better, it was on a open-loop config cuz after i fixed it my cars fuel trim goes from .8 to 1.2, but i cant find any information on what MAF counts are for cuz mine go from 300 to 500.
Old February 18th, 2009, 03:42 PM   #11
KB'd GT
It sounds like a bad maf. Hopefully you didn't touch the sensor. on the stock maf 300 counts should be about 4000rpms in neutral, and 500 is about 3500 rpms at WOT.
Old February 19th, 2009, 08:31 AM   #12
~C~
~C~, The Other White Meat!
~C~'s Avatar
Y2K YellowJacket GT
~TBD~
~C~ is just really nice~C~ is just really nice~C~ is just really nice~C~ is just really nice
Send a message via AIM to ~C~
After you figure out everything, I have the stock MAF if you need one. Let me know.
BLOWN Bumblebeast!
370 rwhp / 381 ft lbs
~Tuned by JJ at WMS
"Like the blind man says......We shall see...."
Old February 19th, 2009, 05:26 PM   #13
1999 mustang Cobra
WTF i cleaned the MAF and replaced the 02 and today it came back with p0174, it seems that my MAF is bad. ill pm about buying yours.
Old February 20th, 2009, 11:59 AM   #14
KB'd GT
Post up a datalog before you go spending money on a maf. It could easily be the tune.
Old February 20th, 2009, 02:59 PM   #15
1999 mustang Cobra
my car is acting really wierd now, it shut its self down when i was coasting down hill then when i started it it up it started revving out of nowhere and when i hit the gas it would studder really bad before it took off so i returned my car to the stock tune and it seems to work fine and my check engine light was gone but on the way home it came back i checked the codes and it had p0331,p1501,p1000,p1501,p0325,p700,p0174, WTF. and the codes that is awalys there isnt theres which is the one for not having cats but my car is finally running normally but a ton of codes poped up
Old February 20th, 2009, 03:08 PM   #16
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
p0331-Knock sensor 2 cirucuit range (bank 2)
p0325- Knock sensor 1 malfunction (bank 1)
p0174- System too lean (bank 2)
p1501- Vehicle speed sensor out of self test range
p1000- monitor testing not complete
sounds like something with your tune, I would get it checked out ASAP. datalog it and send it towards JOE
BUILD 2 IN PROGRESS
Threads Similar to: P0174:dpfe Sensor???
P0174 horsepower builder 99-04 3 December 27th, 2008 04:15 PM
P0174 G.T. Rags 96-98 14 December 2nd, 2007 10:52 PM
EGR and DPFE sensor hell crash8212 96-98 1 July 11th, 2007 06:37 PM
DPFE sensor comes FRIDAY... 00SoSlow V6 Mustangs 9 August 19th, 2006 02:39 AM
DPFE 00SoSlow General Tech 14 August 12th, 2006 02:54 AM
